Low ICP Pressure - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 02-14-2019, 11:11 PM Thread Starter
Low ICP Pressure
I'm at a loss here and I could use some help.
I've got a 2004 f250 6 0 lariat. About a week ago I noticed that I was losing power when I put down the accelerator. I started monitoring the icp pressure and ipr percentage. Accelerating very gingerly everything would look fine. When I got on it enough to make it shift down things would change.
It would downshift, the ipr would jump to 99% but the icp pressure would drop to 600psi.
Then the day before yesterday when I was driving my 2 miles to work I got to a stop sign and saw when my engine idled for a second the oil pressure needle on the dash would drop to the low red zone. But if I touched the accelerator at all it would jump back to normal pressure.
I havent lost any oil or anything, it's still full. I honestly dont know where to start on this.
I was going to check the low pressure pump relief valve to see if a piece of debris had it stuck.
Sent from my SM-N950U using Tapatalk
baronsomedi is offline
post #2 of 6 (permalink) Old 02-15-2019, 11:23 AM
Do an air pressure test.
It sounds like the pressed in ball bearing in the HPOP has come loose.
Also not real familiar w/ IPR duty cycle going above 84 or 85%. I thought that was the max.
Checking the low pressure oil pressure regulator is a good plan.
Also verify that you are using an OEM oil filter w/ an OEM cap.
Mark
bismic is offline
post #3 of 6 (permalink) Old 02-15-2019, 11:43 AM Thread Starter
Run the pressure test on the hpop? And it's a tall cap that came with the oil filter I bought last time I changed it.
post #4 of 6 (permalink) Old 02-15-2019, 03:05 PM
Lots of google hits on air testing the 6.0L high pressure oil system. Several really good you tube videos on it as well. You apply air to where the ICP sensor is screwed into. Another option is to get an IPR adapter so you can test through the IPR port (IPR valve removed of course).
If you use an OEM oil filter with a tall cap, you will not get full oil pressure because the oil filter reservoir drain valve will not get closed completely. Bets to get an OEM cap and then always use OEM oil filters.
Mark
bismic is offline
post #5 of 6 (permalink) Old 02-15-2019, 03:16 PM Thread Starter
Cool I'll check out some videos and run the pressure test. And I'll probably end up getting a short filter to replace this one and switch back to the OEM cap.
post #6 of 6 (permalink) Old 02-15-2019, 03:25 PM
Some of the techs on the pressure testing are DieselTechRon and FordTechMakuloco.
Here are a few
Mark
bismic is offline
Similar Threads
Truck just died, running fine, then started sputtering, then would not start. Thumper723 '99 & up 7.3L Power Stroke Engine and Drivetrain 116 09-02-2007 12:34 PM
NO START HOT smokingf350 Power Strokes 1994-1997 General 12 07-28-2007 10:58 AM
fault codes AndrewA Power Strokes 1994-1997 General 4 03-26-2007 08:43 PM
The CCV Mod--any HP gain/loss due to pressure change? MarvinVR '99 & up Upgrades and Aftermarket - 7.3L Engine 51 01-15-2006 09:09 PM
Autotap FINALLY does CAN!!!!!! HeliPilot Upgrades and Aftermarket - 6.0L Engine 6 11-20-2005 07:27 AM
