Manual Transmission Fluid Change - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-07-2017, 09:26 AM Thread Starter
I'm using Amsoil manual transmission fluid and thinking of changing it with 40K on it. The use is mixed with an empty truck and moderate towing. I don't want to throw away good oil. Any rec's on how many miles I can safely put on it?
Thanks, Pat
06 F350 4x4 XLT, CC, LB, True Blue, 3.73LS, dash mount Pyro (ESOF knob), with stick, 104K miles, BFG AT TKO2 275/70/18/E. Newer Turbo........
97 F350 4x4 XLT, CC, 136k.....SOLD to new owner
GOPDiesel is offline
post #2 of 7 (permalink) Old 06-07-2017, 06:58 PM
klhansen's Avatar
My Photos: (180)
Way more than 40k miles. Your scheduled maintenance manual (assuming you still have one) says 60k miles, normal service.
), AIS,
regulated return,
klhansen is offline
post #3 of 7 (permalink) Old 10-14-2018, 05:33 PM
nate0341's Avatar
I just had a "hot flush" performed on my 6 speed manual by the dealer (forgot to ask them what type of fluid they used). Is there such a thing as a friction inhibitor for manual transmissions? I use Rev-X at oil changes, my buddy swears by that stuff as engine oil additive. If such a thing exists I would like to add to my transmission oil while it is new.
"If you are ashamed to standby your colors, you had better seek another flag."
Anonymous
nate0341 is offline
post #4 of 7 (permalink) Old 10-14-2018, 07:36 PM
klhansen's Avatar
My Photos: (180)
What would you need a "friction inhibitor" for in a 6-speed? It might actually interfere with the operation of the synchronizers. Just my 2cents.
), AIS,
regulated return,
klhansen is offline
post #5 of 7 (permalink) Old 10-15-2018, 05:40 AM
ArcticDriver's Avatar
Agreed.
Just use a high quality ATF like Mobil-1 and its additive package will have all you need.
SOLD:
ArcticDriver is offline
post #6 of 7 (permalink) Old 10-15-2018, 09:13 AM
nate0341's Avatar
I guess I was assuming that if there are addatives for big motors there would be the same for manual transmissions. I read about guys sometimes having problems with their automatics as soon as 40-60K miles on them. I want to do what I can to keep the power train as happy as posible since it has 227k on it.
Anonymous
nate0341 is offline
post #7 of 7 (permalink) Old 10-16-2018, 02:00 AM
I am of the opinion that 7.3’s don’t need oil additive products because motor oils today have such robust additive packages these days.
The automatics are a very diffferent animal from the manual trans but I understand your desire to want to take good care of your ZF-6.
SOLD:
