At my wits end ............... - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 07-30-2019, 11:11 AM Thread Starter
cteno's Avatar
About 6 months ago my 2005 Excursion with 69,000 miles wouldn't turn over. Had it towed to the dealership. Rolls off the flatbed tow truck and starts up. Gets hooked up to the computer and shows no error codes. Bring it home and park it for three days. Go to start it, and same thing, wont start. Have it towed to the dealership. Rolls off the flatbed tow truck and starts. Gets hooked up to the computer and again shows no error codes. Bring it home and it sits for a week. Go to start it, and it wont start.
I then have it towed to Left Coast Diesel and same thing. Rolls off, starts, no error codes. Sits there for a month to get it to get a "non start" and it starts up every time.
Bring it back home after and sits for 4 days and wont start again. ***!?
Anyone here experience this?
2005 EXCURSION LIMITED BLACK 4x4, 6.0 - original owner
1) Suspension=Donahoe Racing 4.5 Edge suspension
2) Wheels=Mickey Thompson M/TŪ Classic Lock 18x10
3) Tires=Nitto Terra Grapplers 35x12.50R18
4) Turbo-back Exhaust
5) Bulletproofed 2016
cteno is offline
post #2 of 11 (permalink) Old 07-30-2019, 11:24 AM
ford_doctor's Avatar
Usually it's the starter when this happens from my experience. I prefer to diagnose something like this by actually verifying the no crank and diagnosing it at that time... given the random intermittent mature that becomes impossible sometimes as you are experiencing.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #3 of 11 (permalink) Old 07-30-2019, 11:38 AM Thread Starter
cteno's Avatar
Ford Doctor, heres a video of what I'm experiencing...............
https://share.icloud.com/photos/00MZ...covery_Bay,_CA
cteno is offline
post #4 of 11 (permalink) Old 07-30-2019, 11:47 AM
You said it won't turn over, but by that you mean it won't start? Clearly it is cranking (which is what I call "turn over").
Anyway - it sounds like a weak crank to me. What rpms are you getting during the cranking?
The fuel level is low - maybe you aren't getting fuel flow.
Mark
bismic is online now
post #5 of 11 (permalink) Old 07-30-2019, 11:49 AM Thread Starter
cteno's Avatar
Originally Posted by bismic View Post
Sounds like a weak crank to me. What rpms are you getting during the cranking?
As far as fuel..... it has a 1/2 tank over 20 gallons at least, just not at the time I took video.
**** I must also mention, I can get it to start when I spray starter fluid into the air intake while someone is turning the ignition, but it starts hard. Once started it purrs like a kitten and runs perfect. Starts up every time that same day. The no start problem occurs when its been sitting for two or three days.
cteno is offline
post #6 of 11 (permalink) Old 07-30-2019, 12:19 PM
Well - it would seem that your issue is fuel related since it starts w/ ether.
When it doesn't start, I would verify the rate at which the secondary fuel filter fills w/ the key on (checking for bubbles while it filled).
Also would be good to install a fuel pressure gauge.
Lastly, it would be good to see ICP data (volts and pressure) when cranking.
I would still like to see the cranking rpms, but that is just me ...........
Mark
post #7 of 11 (permalink) Old 07-30-2019, 12:55 PM Thread Starter
cteno's Avatar
Thanks. I will pass this on to the service manager when I bring my truck in tomorrow
cteno is offline
post #8 of 11 (permalink) Old 07-30-2019, 04:03 PM
Personally I would recommend trying the tests (except fuel pressure) yourself. The last thing any good Diesel Tech wants to hear is "I read this on the Internet ....".
The best way to get engine data is to download a smartphone app (I recommend ForScan Lite) and get an ELM327 OBDII adapter (I recommend BAFX brand). $40 or so total.
The WiFi version probably works for both Android and Apple phones, but I know it works for the i-phone. The Bluetooth version works on Android, but as stated I think the WiFi version works on both.
Mark
post #9 of 11 (permalink) Old 08-14-2019, 11:15 PM
nitrogen's Avatar
Slower cranking, combined with starting on ether says low oil pressure on the high side not making the minimum pressure to start firing the injectors. I would be looking for high pressure side oil leaks, bad IPR, bad pump, things of that sort
nitrogen is offline
post #10 of 11 (permalink) Old 08-14-2019, 11:17 PM
nitrogen's Avatar
It could also come back to the weak crank, which could be one of the batteries being weak, a bad positive cable between the batteries or between the battery and the starter or the same on the ground side. At this age of truck those cables can look good on the outside and be completely shot on the inside. If you have poor Connections in the electrical system there may be just barely enough for it to roll over but not enough to run the electronics at the same time
nitrogen is offline
post #11 of 11 (permalink) Old 08-14-2019, 11:24 PM
If the batteries are charged I would also agree with it being a starter issue. As the go bad they can draw enough amps that the injectors do not fire properly.
DENNY
DENNY is offline
