Need opinions on recent purchase - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By TKOPerformance
  • 1 Post By rock_doctor
post #1 of 8 (permalink) Old 04-24-2016, 03:39 AM Thread Starter
Stink_Pickle's Avatar
My Photos: (12)
Picking up a 69k mile 05 Ex. I had it checked out by a Performance Diesel shop in Tampa, FL (I'm in Northern WI) it's going to be a daily driver with possibly a couple longer road trips a year towing 5-7k
I plan on flying down and driving it home the 1600 miles.
Here is what the shop said and what they want to do the work they recommend.
Diagnosis of entire vehicle:
-New Oil Filter/Cap (wrong one installed) - Needs Oil Change
-New Coolant, add a Coolant Filter
-Rear Vent Motors not working (fuse?)
-Rear HVAC not working, blower not working. (fuse?)
-Power steering flush needed oil dark
-Hot Side Intercooler Boots both leaking
-Oil cooler possibly leaking, has small up top oil leak, need to add
dye to confirm
-Future possible High Pressure Oil Pump (pressure is a little low)
-Standpipes, Dummy Plugs and STC Fitting
-Auto 4wd Engagement does not work, probable wheel
hub seals
-Drives and Stops straight-Mechanically vehicle is everything you would expect from an untouched 69k mile (very clean & well kept)
Repairs:
1 - Oil filter = $25.00
1 - Oil Filter Cap OEM 6.0 = $32.00
1 - Oil Change Service Charge for Oil and Labor = $75.00
1 - 6.0 Hot Side Upper Intercooler Boot hot side = $72.42
1 - 6.0 Hot Side Lower Intercooler Boot hot side = $83.52
1 - Set 6.0 High Pressure Oil Stand Pipes = $124.44
1 - Set 6.0 Dummy Plugs Dummy Plugs = $66.00
1 - 6.0 STC Fitting for High Pressure Oil Pump = $95.72
2 - Gallons Coolant Zerex G-05 = $44.00
3 - Gallons Distilled Water $6.00
1 - Gallon Power Steering = $24.99
1 - Parts Power Steering Flush with Simple Green = $70.00
6 - hours Labor @ $90.00 = $540.00
Total $1259.09*
* Will be enough time in the 6 hours to check out the HVAC, Auto 4WD and check the front end while it's on the lift.
My Stuff:
Install my spare edge insight CTS (Need starter cable with EGT)
Want Rotella ELC Concentrate or similar.
Install my Blue Spring Upgrade
Anything you wouldn't have them do or something I should have them do while they are at it. Its 5 hours each way to the closest diesel shop to me once I get it home.
Rich
KC Stage 3, Full Force 190/75, UCF Ported O-Ringed Heads, ARP Studs, Sinister Up Pipes, ODAWG Ported Intake, Ultra FICM Atlas 40, IPR EGR Delete, Driven RR Kit w/Spring, Fass Titanium 200, BD Exhaust Manifolds, Mishimoto Intercooler and Radiator, BPD Water Pump, OUO Traction Bars, MBRP 4 TB SS Duals, No Limit Cold Air, Sinister Coolant Bypass w/Rotella ELC, Sinister Oil Bypass w/Rotella T6 Syn, Edge CTS w/EGT & FP, Sinister Charge Pipes and Intake Elbow, SCT X4 , DC Power 190 AMP w/1GA Cables, Mishimoto Baffled Catch Can, Hellwig Rear Sway, AMP Steps, 275/65/20, 08 Tow Mirrors, Ram Air Hood, ARB Air Lockers, Warren Diesel Comp Plus Trans, Beans Sump, BD Deep Trans Pan
CC Lariat, SB 3.55 E-Locker, Navigation, Dual Alt, FX4 20" BMF Novakane, Toyo MT's, Air Bags, Rear Sway Bar, Amp Steps, Bilstein 5100's
Stink_Pickle is offline
post #2 of 8 (permalink) Old 04-24-2016, 10:23 AM
I would have the turbo disassembled and cleaned, clean out exhaust back pressure tube and you might as well have them replace the thermostat while the system is empty.
BGilton79 is offline
post #3 of 8 (permalink) Old 04-24-2016, 11:29 AM Thread Starter
My Photos: (12)
Thanks!
Rich
post #4 of 8 (permalink) Old 04-24-2016, 02:14 PM
I'd want the OC delta checked to see if the cooler is bad. Coolant filter kit installed. Personally, on a '05 I'd delete the EGR cooler. And everything that BGilton79 said too.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
post #5 of 8 (permalink) Old 04-24-2016, 04:25 PM Thread Starter
My Photos: (12)
He did take it for a long test drive with his lap top and checked and monitored everything and said injectors and coolant pressures were all good.
The EOT/ECT delta under 10
If it needs a cooler I would definitely delete the EGR at that time.
Thanks TKO
Rich
post #6 of 8 (permalink) Old 04-25-2016, 06:55 AM
Seems the cooler is good then, but if they have to open the cover to fix a leak I'd have them replace the cooler as preventative maintenance and delete the EGR cooler at that time as the intake has to come off.
Stink_Pickle likes this.
post #7 of 8 (permalink) Old 04-27-2016, 12:41 PM
rock_doctor's Avatar
Wow you found a low mileage X with a diesel. That is a rare animal! When they have it apart change out the turbo drain tube and oil pressure line to the turbo. The current one is a braided line with a rubber inside and they can collapse and block oil flow. If the feed is solid steel then that is ok. Don't touch it. Also do the blue spring update to the fuel filter assembly. Remember since the X's were killed off this likely has a late model 04 engine (a few got 05 engines but very few). So that means it likely has the iron HPOP cover and the swash plate pump. See if a magnet will stick to the cover under the turbo. If it does then it is an 04, if it does not then it is an aluminum cover and you have an 05 engine with the STC fitting. The 04s with the Iron cover do not have the STC fitting. Good luck, we love our 05 X. Has been a good truck.
rock_doctor is offline
post #8 of 8 (permalink) Old 04-27-2016, 02:24 PM Thread Starter
My Photos: (12)
On the carfax it says 8/18/2005 Vehicle manufactured and shipped to dealer.
I will have them check the cover to verify, thanks for the info!
Rich
