Never ending? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 12-03-2018, 04:32 PM Thread Starter
Never ending?
I have an 03 6.0 and I’ve already changed 1injector and all the injector seals ran perfect for 6 months and it’s back at it. Is it even worth it? Say I changed all of the injectors and Got the bullet proof kit with the head studs and get delete oil pump ex. Is it still going to be a money pit after that or what I need opinions...
Jon036.0 is offline
post #2 of 4 (permalink) Old 12-03-2018, 05:35 PM
bobofthenorth's Avatar
Originally Posted by Jon036.0 View Post
I have an 03 6.0 and I’ve already changed 1injector and all the injector seals ran perfect for 6 months and it’s back at it. Is it even worth it? .
"It's back at it".... back at what? We need a lot more information.
Owning an older - maybe end of life - diesel is not for the faint of heart.
My own 6 has been really good to me for over 100,000 km now but I have been perfectly aware from the beginning that its fundamentally a grenade with wheels at each corner. It may go off at any time. Right now I've got a fairly regular contribution code which is telling me that its probably time for injectors. They've got roughly 400,000 km on them so no surprises there. I'm also seeing 10+ degree deltas on my oil/water temps so probably coming due for an oil cooler. I've got no particular reason to think I need a turbo other than that its also got around 400,000 km on it. So add all those up and maybe I should be looking at a long block. Trading it into an early production 6.7 would cost me roughly $0.10 per km so that makes a $10,000 Canuck bux long block look pretty attractive. Like I said - owning an older diesel is not for the faint of heart. What we should be doing is driving gassers but some of us like the smell of partially burnt diesel fuel.
2006 F250 6.0 4x4
bobofthenorth is offline
post #3 of 4 (permalink) Old 12-04-2018, 09:30 PM Thread Starter
Back at it as in I have another injector out... and as far as it being an end of life it only has 160000 miles it has a lot of life left I would think.
Jon036.0 is offline
post #4 of 4 (permalink) Old 12-05-2018, 01:20 PM
150,000 to 200,000 is the average life of injectors. Some get much more, some a lot less.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
