Oil temp skyrockets in park - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-07-2019, 11:04 AM Thread Starter
So I’m driving around town. Oil and water temps about 196 all day.Hit a stop and then get back in and crank it up. Sounds great.
Start to drive and it sounds whiny, like I’m in the wrong gear. I take it slow and go thru all the gears. No problem. I look at the gauges and I’m 247 for oil and water.
I pull over and shut it off for a few
Minutes. After ten, I crank it up and look at the gauges and oil is climbing 210-211-213.. a degree every couple of seconds.
(In park). Tried this a couple of times and just decided to tow it to a shop before something really bad happened. It might’ve already.
Bad sensors? Blown oil cooler? I’ve had a delta of 9 for the past couple of years. Nowhere near the 15 degree mark..
DJ
2004 F250 4x4 6.0 Powerstroke - 75k Miles- Bulletproof EGR, Sinister Coolant Filter, Blue Spring Upgrade, Rotella ELC Red, Scanguage II
Dragojazz is offline
post #2 of 6 (permalink) Old 03-07-2019, 01:41 PM
Hard to imagine both coolant and oil temps going bad at the same time.
How is your coolant level? Maybe a water pump failure?
Coolant temps over 221*F will cause the PCM to begin to restrict the engine load.
Mark
bismic is online now
post #3 of 6 (permalink) Old 03-07-2019, 05:25 PM Thread Starter
I just called the shop. Blown head gaskets. At 137k, I thought I was safe! Man..
DJ
post #4 of 6 (permalink) Old 03-08-2019, 04:19 PM Thread Starter
Just curious. How much would a otherwise- excellent running 6.0 with 135k with blown head gaskets be worth?
DJ
post #5 of 6 (permalink) Old 03-15-2019, 09:32 PM
Any time I have ever bought a vehicle with issues I assumed the worst and paid like that and got it priced like that. Says its a 15K truck and it has blown head gaskets. There is no way to know if the heads are cracked and what else they may need. So I would say $8K because I may have to do $7k and wouldn't want to have more than the perfect running price in it once I got it to that condition. Tires, brakes or anything else I see that it will need soon also reduces my offer. If you went to trade it they'd probably put $4500 in it in real money.
BUT, you weren't blowing coolant out of cap. Was the coolant tank empty? I have had 6.0 with bad fan clutch and they would be fine until they weren't and the PCM would command fan % up but the fan clutch would not drive fan faster and the temps would shoot up.
DO you think the shop did a cooling system pressure test or ??? Did they just say it's a 6.0 and needs head gaskets?
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #6 of 6 (permalink) Old 03-23-2019, 02:02 PM Thread Starter
They said it was pressure tested and failed.
At this point, the heads are at the shop. I should get it back next week.
I love the truck.. it's still low mileage for a diesel. I want to keep it, despite that video with Hitler's 6.0 on youtube.
Coolant was pretty empty. I knew this would probably happen one day, and I was somewhat prepared to get it done. It's always been on the list. I guess this just expedited things a little.
Now.. what tuner am I going with?
DJ
Similar Threads
Cracked front cover '99 7.3L powerstroke Nautique27 '99 & up 7.3L Power Stroke Engine and Drivetrain 31 11-29-2014 06:44 AM
Bulletproof Diesel Oil Cooler INSTALL -Snake- Upgrades and Aftermarket - 6.0L Engine 7 10-12-2012 11:42 AM
Burns Engine OIL InTheDogHouse 6.9L IDI Diesels (Not Power Strokes) 5 07-30-2010 03:26 PM
Oil change int. jjurich '99 & up 7.3L Power Stroke Engine and Drivetrain 114 08-22-2007 12:30 AM
AMSoil Djc94 '99 & up 7.3L Power Stroke Engine and Drivetrain 8 01-10-2006 06:27 AM
