Orange/Red spillage from degas. - Diesel Forum - TheDieselStop.com
LinkBack Thread Tools
Old 07-31-2018, 06:43 PM Thread Starter
Hey guys so I am new to diesels and recently purchased a 2004 lariat 6.0L
I looked online and didnt find this issue, so i am sorry if this is a repeat.
When i purchased it I did the temp test between the engine coolant and the oil. It never got greater than 5 degrees. Temps reached to about 180-185F.
I opened the oil cap and there was no blow back.
At the time there was no residue on the degas cap.
So I thought the truck was in decent conditions. besides the Ac not working.
I drove the truck for not even half a tank of gas and then i went to do my weekly fluid check that i usually do to my car and now truck as well. When i opened the hood there was a red/orange overflow around the degas bottle and inside it was like a dried up powder.
I was freaking out that the head gasket might be bad.
I was told it could be the degas cap.
I recently got a scangauge 2 that i will be running the temps to make sure they do not vary more than 15 degrees.
Should I just get some motorcraft coolant fill it back up (since its empty) and replace the cap?
Should I be afraid to drive it 500 miles on a road trip unloaded?
Has anyone run into this issue or know what it can be?
Any help or direction would be appreciated.
I uploaded pictures to show the problem.
Boomer Pledge is offline
Old 07-31-2018, 10:35 PM
ArcticDriver's Avatar
I do not have knowledge of the 6.0 but a chalky, red substance does not sound like oil residue.
What color is the original coolant? This info will help determine which coolant you want to add.
Did you say your degas bottle went from full to empty in less than one tank of fuel?
Never hurts to buy a $12 Motorcraft degas cap from Amazon.
Much respect for your weekly underhood inspections.
SOLD:
ArcticDriver is offline
Old 08-01-2018, 05:18 AM Thread Starter
The original coolant was gold in color. They said it was the motorcraft gold coolant. I read that it could be rust and to do a coolant flush. Yes sorry less than half a tank of fuel I can no longer see any liquid in the degas reservoir.
I am going to buy a cap and see if i flush it with some distilled water a couple of times then refill it and see if that fixes the issue?
Old 08-01-2018, 06:28 AM
As stated on FTE - If you go back in w/ Gold, and you actually do have a head gasket leak or an EGR cooler leak, then you are risking plugging up and/or rupturing the oil cooler. Ford Fold coolant will gel when exposed t combustion gasses (low pH gas).
First task would be to see how much fluid was lost since the degas tank is empty. Add water until you get the degas bottle filled to the minimum level again. Post up how many gallons that was. Your entire system holds 7 gallons of coolant.
Once you determine how much of the 7 gallons were lost, Then you can do a quick leak test to see if you have a degas bottle crack or if a hose or the water pump is leaking. Also verify that the sealing surface for the degas bottle cap is flat w/ no nicks/burrs. Sand it flat and smooth if it isn't already. Now is the time to add a pressure gauge in the system (also as mentioned on the FTE post). You can pressurize the system to 15 psig and then watch for leaks and also see if the pressure holds or drops.
After that, it is HIGHLY recommended to do all the flushing now and then switch coolants.
What you need to know is that a degas tank operation is NOT the same as an overflow tank.
With a system that uses a radiator cap and an overflow tank, you can lose ALL of the fluid from the overflow tank and still be ok. The radiator cap (if still good) will still maintain a pressurized system.
When the degas bottle is empty, you have depleted a significant portion of the volume that actually circulates AND you have lost any pressure benefit for boil over protection.
Mark
bismic is offline
Old 08-02-2018, 05:39 PM Thread Starter
Also @bismic i bought a scangauge 2 to measure temps and when i entered the codes for the EOT the name just appeared there but didnt provide any info. Have you ran into this problem? sorry for annoying you.
Old 08-02-2018, 05:47 PM
That is good - a gallon isn't a crazy amount anyway. You might want to drain some coolant from the radiator drain valve and examine it (color, sludge, etc).
I have not experienced the issue w/ the EOT on the scangauge, sorry.
Do you have the programming for it?
Mark
bismic is offline
Old 08-02-2018, 05:56 PM
You must have miss-entered the numbers/codes for the EOT data in ScanGuage. I've got two 6.0's and run ScanGuages in both of them and don't have issues with the EOT value. The MAT value reads as -40 for some reason but that has been the case since the beginning so I don't think it's a legit concern.
dillon134 is offline
Old 08-02-2018, 06:15 PM Thread Starter
@bismic I drained a little and this is what i got. It doesnt look that bad?
So i am hoping it is just the cap?
Thank you @dillon134 ill go recheck them but i thought i double checked it.
Old 08-02-2018, 06:48 PM
For Ford Gold coolant it doesn't really look all that bad. Is it thick or does it contain solids?
Mark
bismic is offline
Old 08-02-2018, 08:41 PM Thread Starter
No not really. its just diluted now since i added a gallon of distilled water and not a 50/50 mix.
So should I flush it anyway and fill it up with a better coolant? which would you suggest @bismic?
Old 08-02-2018, 08:52 PM
I would still highly recommend to flush it. I would probably only use the Restore (not the restore plus).
Use an EC-1 rated ELC coolant (you will need 4 gallons of the concentrate)
Probably the best is the Cat ELC coolant if you have a Caterpillar store near by.
You can also get some EC-1 rated ELC coolant at an International dealership (Fleetrite ELC) if there is one close to you.
Mobil Delvac ELC is an EC-1 rated also.
I even think that Peak Final Charge is one, but you would have to verify that.
Same with Shell ROTELLA® ELC AFC.
https://www.ford-trucks.com/forums/1...c-coolant.html
Mark
bismic is offline
Old 08-02-2018, 08:56 PM
Again, you will want the concentrate, because doing the 3 or so final flushes with distilled water will leave about 2-2.5 gallons of distilled water in the block (maybe even a little more). The way to get to a 50/50 concentration is to add 3.5 gallons of concentrate and then top-off with more distilled water - whatever it will take to get to the desired level).
After driving it, the level will settle a little and after a while and you will need to add a little more water. That is because of air left in the system. Sometimes I will even "burp the system" (remove the degas carefully and with a thick towel when the system is hot).
The target fill is at the "MINIMUM" line of the degas bottle. You really do not want to run it any higher than that.
Also, if you have access to a vacuum fill apparatus, it is best to use that! Then no need to burp it to get the air out.
Mark
bismic is offline
Old 08-02-2018, 10:04 PM
And its no problem if you are strong on coolant 5%.
Just not strong on water.
SOLD:
Old 08-08-2018, 04:19 AM Thread Starter
@bismic, thank you for the info. I havent really been able to work on the truck since work has been really busy.
I did want to add some additional details tho. Before noticing the coolant was low the truck was stuck in park when I would start the car up. I would have to bypass and turn the key to the on postion(before the engine started) and put it in neutral and then start it. Could that have been because the coolant was low? I remember when I filled it up with the gallon of distilled water it did not make me do the whole bypass procedure. There is still no check engine light or any codes pulled when i scan it.
Also I noticed that a light white smoke/water vapor came out of the exhaust. I read that could one of two things. Either unburnt fuel or water coming from the coolant.... Could it be anything else?
Old 08-08-2018, 06:54 AM
The issue w/ the gear shift lever is not related to the low coolant level. That sounds like a neutral safety switch that is acting up.
Since the coolant loss happened quickly and you see white smoke, it is most likely an EGR cooler leaking coolant into the intake manifold (and then it goes through the engine). The white smoke could be an injector dumping fuel, but with the loss of coolant, it seems more likely it is an EGR cooler.
If you are going to deal w/ an EGR cooler, then I would just fill with distilled water and then drive it just enough to get it fully warmed up. Then park it on an incline (nose down), wait an hour or so, then pull the EGR valve and look for moisture under the valve in the intake.
Unfortunately, when you have an EGR cooler failure it can lead to head gaskets leaking (from increased cylinder pressure due to the incompressible liquid in the cylinder). Also, EGR coolers fail many times due to oil coolers plugging up and restricting water flow to the EGR cooler.
When you drive the truck to get it up to temperature, you need your scangaugeII functional to read engine parameters. Specifically we need to know the oil and coolant temps AFTER the engine has fully heated up. If the oil temp stabilizes at a temperature that is 15 or more degrees above the coolant temp, then you need a new oil cooler.
We already know you need to get rid of the Ford Gold coolant, but it sure seems wise for you to assess these other areas first.
Lastly, you need to confirm what engine you have in your 2004 truck. They came w/ an 03 engine and this setup is called an "early 04". They then did some changes and called it a late 04 (actually there is a mid 04 also, but immaterial to you at this point). Find your ICP sensor. If it is on the passenger valve cover, then you have the late 04 and you are much more likely to have an EGR cooler. One of the 04 "upgrade" was to go to a finned type EGR cooler for more heat exchange capability. Unfortunately it is a weak design and prone to leaking.
An ICP sensor behind the turbo means it is an 03 engine and that it has the shell and tube design for an EGR cooler. They can still leak, but less often.
Mark
bismic is offline
