i have a 2003 f250 6.0L and earlier today i noticed my check engine light was on, when i got home i checked to see what codes were being sent to my tuner. p2285 - injector control pressure sensor circuit low, was a code i hadn’t seen before. does this mean that i have a bad sensor? and i need to replace it? or what else could cause this code? the truck idles, runs, and starts normal. did i catch it early before the bad sensor causes it to run bad? or is it something else?
