Please help the newbie! - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 12-04-2015, 07:09 PM Thread Starter
Unhappy Please help the newbie!
I recently purchased a 2004 6.0 e350 van with 80,000 miles for my small business. The check engine light came on and I'm noticing blue-ish smoke coming out of the exhaust. The blue-ish smoke occurs during acceleration, however, it clears out when the engine has been idling for about a minute. I believe the engine is running as it should, I haven't experienced a loss of power or noticed any strange noises. I have noticed the exhaust smells quite rich, it smells similar to my old 2000 7.3.
I have done quite a bit of research and it seems typically these are symptoms of either bad injectors or bad turbo seals. Would bad turbo seals throw a code? Has anyone else experienced similar symptoms? If so, any feedback or advice is greatly appreciated!
drew5250 is offline
post #2 of 17 (permalink) Old 12-04-2015, 07:26 PM
Originally Posted by drew5250 View Post
I recently purchased a 2004 6.0 e350 van with 80,000 miles for my small business. The check engine light came on and I'm noticing blue-ish smoke coming out of the exhaust. The blue-ish smoke occurs during acceleration, however, it clears out when the engine has been idling for about a minute. I believe the engine running is as it should, I haven't experienced a loss of power or noticed any strange noises. I have noticed the exhaust smells quite rich, it smells similar to my old 2000 7.3.
White Smoke is usually caused by coolant being burned, Black Smoke is usually caused by excess Fuel (Running Too Rich), and Blue Smoke is usually caused by Oil being burned. I would suspect it would be the Turbo Seals, have you checked your Turbo Outlet to see if there is any oil on the inside of it yet?
CycleVIN is offline
post #3 of 17 (permalink) Old 12-04-2015, 08:15 PM Thread Starter
I haven't checked it yet, but it seems like a likely culprit. I'm puzzled because the truck has a really rich diesel smell, more so than other 6.0 powerstrokes I have encountered (it is bone stock and has a cat). Perhaps the rich smell is from oil in the exhaust being burnt off. Can anyone explain why the smoke is present only during acceleration? I know egt's go up with acceleration, the higher temp could burn off oil in the downpipe if I have bad seals. Has anyone else had a check engine light for bad turbo seals or do you think I may have something else going on in conjunction with bad turbo seals? Thanks!
drew5250 is offline
post #4 of 17 (permalink) Old 12-04-2015, 08:50 PM
yan7gin's Avatar
White smoke can be raw diesel fuel
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #5 of 17 (permalink) Old 12-05-2015, 01:30 AM
Under Load the oil pressure increases, if the seals in the turbo are bad, then more oil is going past them under load than at idle, which is why you see more blue smoke while accelerating.
White smoke can also be caused by transmission oil, that's why I said "usually".
CycleVIN is offline
post #6 of 17 (permalink) Old 12-05-2015, 12:14 PM Thread Starter
That seems like a very logical explanation. I noticed that if the engine is under a load prior to reaching operating temp, there is no smoke. The smoke starts once temps get into the operational range...this 6.0 has felt like a roller coaster relationship. Sometimes you're madly in love, other times you're just mad.
drew5250 is offline
post #7 of 17 (permalink) Old 12-05-2015, 04:02 PM Thread Starter
Just an update, I took the van for a quick spin around the block today. I noticed that the smoke is more of a white-ish color and is definitely not steam. The white smoke lingers and will not dissipate the way steam does. The exhaust has what I consider a strong diesel smell. Smoke only happens when the truck has been warmed up close to operating temperature and after accelerating. During warm-up and high idle, zero smoke is observed. I spoke with the previous owner, he hasn't driven the truck in nearly 6 months and I'm sure it still has some old fuel in the system. I ordered oil, archoil 9100, Motorcraft oil filter, and a new air filter. I'm not sure if it's a bad injector, the engine seems to be running quite strong aside from the smoke, I do not hear any cylinders misfire.
drew5250 is offline
post #8 of 17 (permalink) Old 12-05-2015, 08:05 PM
yan7gin's Avatar
[QUOTE=CycleVIN;3977361
White smoke can also be caused by transmission oil, that's why I said "usually".[/QUOTE]
Kind of lost here... How trans oil can reach inside the cyl....
F350 2002 7.3
yan7gin is offline
post #9 of 17 (permalink) Old 12-06-2015, 12:43 AM
Who said it was inside the cylinder?
CycleVIN is offline
post #10 of 17 (permalink) Old 12-06-2015, 09:04 AM
yan7gin's Avatar
Im just trying to understand and learn.. I know white smoke is normally coolant. When i add it can also be raw fuel it wasn't to attack you but add another possibility.
For the trans oil i just want to understand and would be nice to have a explanation. That's the first time i hear oil trans will push white smoke.... I'm just trying to learn and pretty sure im not the only one.
F350 2002 7.3
yan7gin is offline
post #11 of 17 (permalink) Old 12-06-2015, 09:58 AM
Smoke color is to engine diagnosis what licking your finger and sticking it up is to wind speed detection.
White smoke is raw fuel or coolant. If raw fuel you would have a misfiring cylinder and rough running. If its coolant going through cylinder that also causes misfire. If it is coolant leaking from egr cooler it can go out exhaust and smoke white with no abnormal running of engine.
Black smoke is over fueling or lack of air. low turbo boost causes black smoke but also stuck open egr valve which makes the overfed exhaust gas replace the oxygen.
Blue smoke can be oil but it can also be injector timing. On 6.0 FICM issues can make blue smoke when there is ZERO oil consumption.
You do not list the code read from vehicle. That is the place to start.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is online now
post #12 of 17 (permalink) Old 12-06-2015, 06:04 PM Thread Starter
I'm waiting for my code reader to arrive. I was just seeing if anyone else has had similar issues and what they did to solve the problem. From what I've read on the forums, a bad egr cooler will results in steam immediately after startup and during idle. My issue only occurs when I'm accelerating or just after acceleration, the smoke clears out after a couple minutes of idling. I have kept a close eye on my coolant levels, my van is not consuming any coolant.
drew5250 is offline
post #13 of 17 (permalink) Old 12-06-2015, 06:23 PM
yan7gin's Avatar
Thanks for the clarification, thats what i was thinking
F350 2002 7.3
yan7gin is offline
post #14 of 17 (permalink) Old 12-06-2015, 11:52 PM
Leebetter's Avatar
That's a chore. Anyone have a guesstimate of cost to replace said turbo seals?
2005 6.0L PowerStroke. 210,000 mi., 6500 Hrs. All stock.
Leebetter is offline
post #15 of 17 (permalink) Old 12-07-2015, 12:42 AM Thread Starter
I called a local turbo specialist shop and they quoted me $450. Of course, most of the price is labor for removal and installation of the turbo plus $155 for the garrett rebuild kit. Apparently, the turbo on the van is one of the few parts that is easier to access than the F-series. The labor on the F-series will probably cost more.
drew5250 is offline
