Please help the newbie! - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 17 (permalink) Old 12-07-2015, 10:40 AM
Rebuild it your self. It is very easy. The only things in them are two sleeve bearings, a thrust bearing and sealing rings. Cleanup is the important part. Look at some of the Youtube videos of Dieseltech Ron on it.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #17 of 17 (permalink) Old 12-07-2015, 07:46 PM Thread Starter
Thanks for the advice, I watched the video and it seemed pretty straightforward. I don't think my turbo seals are the issue, the smoke appears to white in color. The van sat for about six months with no use. I think stiction is a likely culprit. I'm going to change my oil and add Archoil 9100. I know Archoil is not a cure-all, however, we'll see if it makes a difference in my case.
drew5250 is offline
