Post your miles - Diesel Forum - TheDieselStop.com
post #1 of 282 (permalink) Old 04-15-2007, 07:19 PM Thread Starter
Post your miles
Just interested in knowing the how many miles you've put on your 6.0's and what problems you've had during the life of your vehicle. I own an 05 6.0 excursion w/ 31,000 and have not had any problems to date
tony1021 is offline
post #2 of 282 (permalink) Old 04-15-2007, 07:22 PM
Re: Post your miles
If you really want it here goes.
2006 with 6600 miles
Check Electric Trottle Cable Engine light
Top molding on tailgate (new one had to beed ordered)
Radio, windows, Power rear window not working replace fuse position 42
Heated seat switch not working (new switch put on order)
Brake lights and turn signals for trailer connection not working replaced fuse in under hood fuse panel
Replace heated seat switch
Vibration in steering wheel/ front end
Anti-locking brake system (ABS) light was on, then went off,
Speedometer went to zero, gradually worked its way back up
Vibration in Front end when drive more often when turning
brakes some make noise when it cold
When starting truck in the cold, does not always start, like starter does not engage properly
Vibration still in the steering wheel (more than ever before)
Parking brake pedel goes to the floor
Cold Start Concern, Cracks long, Misfire, White smoke
Bangs hard when going into 4 wheel drive when moving
2008 Dodge 1500 Quad Cab SLT
2006 F-350 4x4 Crew Cab SB 6.0L Diesel Lariat (trade)
1996 F-250 CC SWB 7.3L XLT traded
Markford14 is offline
post #3 of 282 (permalink) Old 04-15-2007, 07:25 PM
wjb
wjb's Avatar
Re: Post your miles
19020 miles, bought my 2006 in aug 05.Has been a great truck!!!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Now if you have the hour meter fiqure out what your average mph would be.At last check mine was 45 mph.....
2006 F350 LARIAT CC DK GREEN/AZ BEIGE DIESEL!
limited slip ESF Moonroof Rooflamps Tow command and camper package Snow plow pkg.
wjb is offline
post #4 of 282 (permalink) Old 04-15-2007, 07:32 PM
Re: Post your miles
I have an 06 with 32,000
at 6,000 mile the first turbo went at 29,000 the 2nd turbo went!
Have changed the EGR valve and changed the exaust back presure sensor 2X
Changed the driver side mirror once because it shorted out!
Also had to get the truck repainted as soon as I got is as it had speckles of another color under the clear coat!
[img]/ubbthreads/images/graemlins/confused.gif[/img]
hamp is offline
post #5 of 282 (permalink) Old 04-15-2007, 07:52 PM
Re: Post your miles
2005-18,600 miles engine out twice for oil leak. One cab off,one out the front. Hanging drip transformed into filling the starter with oil. Egr cooler went bad, Oasis 8 pages .
ron1258 is offline
post #6 of 282 (permalink) Old 04-15-2007, 07:55 PM
Re: Post your miles
see below
05F250PS is offline
post #7 of 282 (permalink) Old 04-15-2007, 07:56 PM
KingKong's Avatar
My Photos: (11)
Re: Post your miles
2007 4300 mile and all is great never been back to dealer for anything
Now for the 2004 Thats another story Ford owners it now...... at 9000 miles it had had the head gaskets and heads replaced twice alone with other things but don't get me started......
07 F-250 6.0 L CC XLT 4x4 Red Addons: ARE Cover, WheelSkin Cover, PML Rear axle Cover, Dieselsite Coolant Filter, C-better Mirrors,Gauges Isspro Fuel press. Trans Temp. EGT gauge. Gauges from Diesel Manor. Edge Insight CS (For EOT & ECT)
04 F-250 6.0 L CC XLT 4x4 White Buy Back
...... 06 Jayco Travel Trailer 32'
KingKong is offline
post #8 of 282 (permalink) Old 04-15-2007, 08:12 PM
Re: Post your miles
Purchased July 30 2006, 24672 miles, not one thing wrong. [img]/ubbthreads/images/graemlins/grin.gif[/img](knock on wood).
06250stroke is offline
post #9 of 282 (permalink) Old 04-15-2007, 08:19 PM
Re: Post your miles
2007 Purchased Oct 06, 3900 miles, no problems other than squeaky rear springs
- 2013 Lariat Crew Cab 4x4, Tow Package, 6.7, 3.55s
- 2008 XLT Crew Cab 4x4, Tow Command, Camper Special, Monroe Gas-magnums A GOOD OLD FRIEND OFF TO A NEW OWNER
- 2002 F250 S/C 4x4 PSD, 4 inch turbo back, zoodad, pre-pump and tank mods, QLJ5/PMT1 Tipton Econotune, Sonnax/Tricumulator, ISSPRO under cubby mount gauges, Prodigy controller, 3.5 inch rear blocks, KYB Monomax Shocks...GONE BUT MISSED
- 1971 F100 Ranger XLT shortbed 4x4, 445 FE, hotrod resto
- 1970 Fastback Mustang, SEFI 489 cid FE, TKO-600 5 speed, 4.11 9 inch, ported KC alum heads
My427stang is offline
post #10 of 282 (permalink) Old 04-15-2007, 08:28 PM
Re: Post your miles
nice mustang
04 F-250 XLT Crew 8' 4x4 6.0 bought used "buy back" from Ford.adj.ped? back-up sensers
Installed spring leveling, rear F350 blocks.35's, adj.tracbar, cab lights.
donf610 is offline
post #11 of 282 (permalink) Old 04-15-2007, 08:29 PM
Re: Post your miles
i have an 06 purchased in oct of 05. truck has 33k miles on it. just paid it off. i intend to own this truck forever. best car i have ever owned.
ncmallard78 is offline
post #12 of 282 (permalink) Old 04-15-2007, 08:30 PM
Re: Post your miles
2003 Bought at 102,000 miles, has 104,900 on it now. Runs like a raped ape! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
weasel79 is offline
post #13 of 282 (permalink) Old 04-15-2007, 09:03 PM
Re: Post your miles
04 F350 CC/DRW/4.10/XLT SPORT-54k: 2 EGR/1Shift Solinod/1 Oil Pan Gasket/3 Recalls-Transmission/Harness/EPS: all required service completed by dealer per FMC up to date: avg 13.5-14.0 MPG: overall great truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
PSD2004 is offline
post #14 of 282 (permalink) Old 04-15-2007, 09:13 PM
Re: Post your miles
04/04 egr cooler, new [email protected] 32000, wiring harness , ficm, head gasket, 8 new injectors, couple flashes has 102k on it now runs good till next time gonna drive till wheels fall off isn't worth nothing on trade dealer don't want it Im goona enjoy my 5 cent a mile depreciation from here on out.
08 LTZ CC D/A 4X4 Dually
rebuilder is offline
post #15 of 282 (permalink) Old 04-15-2007, 09:17 PM
Re: Post your miles
2004 bought April 04. 53k miles with one EGR valve replaced under warranty around 30k miles.
The work truck is an 06 F550. 34k miles on it with zero problems.
2005 F-350 SRW, Lariat, 156" WB, 4x4, auto, True Blue, 96k miles, stock.
Canyonero02 is offline
