Purchasing a FICM - Diesel Forum - TheDieselStop.com
 2Likes
  • 2 Post By bismic
post #1 of 10 (permalink) Old 09-13-2019, 01:24 PM Thread Starter
Purchasing a FICM
Stay away from Autoecu.com - you'll not get what you think you will and when you return it, they hold your refund for 6 weeks+.
We have a problem with a 2003 6.0 - absolutely everything has been checked, we have followed Ford's diagnostic guide for repair, had multiple Ford mechanics look at it along with our own work and no one has been able to come up with an answer. This truck ran fine until mid-July, then just up and refused to start. There is no injector rattle - none.
Honestly I would ask for ideas but we've exhausted everything and are looking for another truck at this point.
chasracer54 is offline
post #2 of 10 (permalink) Old 09-14-2019, 09:46 AM
Assume you have a scanner/gauge of some kind that reads the PCM data. Is the truck cranking but won't start?
dillon134 is offline
post #3 of 10 (permalink) Old 09-15-2019, 07:45 AM
ford_doctor's Avatar
If there is no injector pre-cycle when turning the ignition on and the FICM power and ground circuits have what they are supposed to it is likely the FICM has failed. Your Ford dealer can sell you one that is pre-programmed and should function out of the box. What concerns me is that if I read your post you got a FICM from Auto ECU? Did it work? If no pre-cycle exists you could also have a shorted injector or injector harness which WILL take down the module and cause your problem. The harnesses on 2003 6.0L engines were a HIGH failure rate item and the harness was updated to resolve the issues.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #4 of 10 (permalink) Old 09-17-2019, 01:58 PM Thread Starter
We have gone through the entire harness assembly (what a mess), fixed a couple of minor issues and verified every lead in it at 100% connectivity except of course for the ones that connected to harness shielding. The FICM was not the issue and upon returning it, we knew about their 30 day refund policy which we were okay with initially. But how long does it take AFTER the returned unit is deemed A-OK within a couple of days of arrival and paperwork is submitted to accounting? It reached a point after 40+ days that I called them out on it - basically they were just holding funds to collect interest on the monies. That's a garbage way to run a business and I suggest that everyone stay away from the outfit. Plus the FICM that we received looked like it had been through the blender so my take is that if you do not purchase one of their premium units, you get whatever they want to send you.
We are looking at a newer truck tomorrow evening so might just give up on this one.
post #5 of 10 (permalink) Old 09-17-2019, 03:30 PM
You are lucky they offer refunds. Any module that I have taken from the parts counter is non-returnable once the box is opened or it is plugged in.
post #6 of 10 (permalink) Old 09-17-2019, 07:02 PM Thread Starter
Nothing lucky about it - we wouldn't have bought the part if there wasn't a return policy.
post #7 of 10 (permalink) Old 09-17-2019, 09:35 PM
What he is saying is that you are lucky ANYONE offers returns on electronic components.
I loaned a FICM out once. Came back a mess. The power board was completely burned up. No offer of apology, let alone a mention of compensation.
Most people just don't know what they are doing.
IMO it is a poor business practice to take back electrical and electronic components.
bobofthenorth and ford_doctor like this.
Mark
bismic is offline
post #8 of 10 (permalink) Old 09-18-2019, 09:31 AM Thread Starter
Maybe so, but again we wouldn't have made an online purchase for a rebuilt, overhauled or whatever piece without a return policy. Problem is, they misuse it and if I can keep one person from making a purchase from them - then mission accomplished. Lousy businesses need to go away in my opinion.
post #9 of 10 (permalink) Old 09-18-2019, 10:30 AM
Again - if you do business w/ a company that takes electronics back, they will make up for their losses one way or another.
I agree - stay away from those companies in the first place. People return garbage, so the next guy gets garbage. You don't get things for free very often in this world. In the overall scheme of things 10-15 extra days is nothing.
Have you verified you are getting cam/crank sync when cranking?
Mark
bismic is offline
post #10 of 10 (permalink) Old 09-18-2019, 03:27 PM Thread Starter
Yes we have.
