Trans issue - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 10-16-2017, 08:09 PM Thread Starter
JoeD7.3's Avatar
Trans issue
trucks an 04 with 120k i have spd tunes and wasn't having an issue until i installed a ficm tune. As soon as i took off right after loading it i got a terrible 3-5 shift flare. Dropped pan found this clip in the pan , most said it was a parking pawl. i replaced the 3-5 solenoid with the EPC and took for a drive. The truck went into limp mode and threw p0700 and a code about FICM tuning not being compatible. I have access to ford PTS but they don't show p0700 as a code. I was scanning with a snap on solos pro but if i can at work ill try to get the IDS On it. Thanks
95 F-250 3.55s Auto 33s X 12.50s . 3" DP 5 inch , WW2 , PHP Ts 6 , Flatbed. Extended Cab . 6637 ,
Parts replaced Radiator , all 4 balljoints (moog) starter , fuel pump ,Fuel bowl rebuild , Injector orings and cups, Rebuilt trans ,100k mile transfer case ujoints , both rear leaf packs. 274k and counting
JoeD7.3 is offline
post #2 of 9 (permalink) Old 10-16-2017, 08:37 PM
STMPDUST's Avatar
Well i am pretty sure it needs to relearn, experts may reply or the search button will probably help tons.
2015 KR Dually CC 4X4 Bronze Fire HC
2011 KR Dually CC 4X4 Royal Red
2005 Eddie Bauer Excursion 4X4 ,White
STMPDUST is offline
post #3 of 9 (permalink) Old 10-16-2017, 08:54 PM
Mark Kovalsky's Avatar
My Photos: (6)
I think you have software compatibility issues. Can you set it back to stock and see what it does?
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #4 of 9 (permalink) Old 10-16-2017, 11:29 PM Thread Starter
JoeD7.3's Avatar
Thank you for getting back so quick. It is possibl as I had no real issue before. I set the ecm tune back to stock and it's still the same. I have to set the ficm back with an ids
JoeD7.3 is offline
post #5 of 9 (permalink) Old 10-17-2017, 04:32 PM Thread Starter
JoeD7.3's Avatar
I have an update, I cannot remove the FICM tune without an ids. I message Amber at FICM repair she said its a soft code and won't cause any issues. The truck now is in limp mode, still getting p0700 and its stuck in 5 gear. It goes into reverse easy and quick and into drive fine. Not sure where to look at this point. I almost think its a wiring issue. I have Fluke meter and Access to PTS if i could narrow it down to an actually code.
JoeD7.3 is offline
post #6 of 9 (permalink) Old 10-17-2017, 08:46 PM
My Photos: (6)
I Not sure where to look at this point. I almost think its a wiring issue. I have Fluke meter and Access to PTS if i could narrow it down to an actually code.
So the problem appeared as soon as you put in the FICM code, and you think it's a wiring issue? Really? And you don't know where to start? I told you where to start. If you don't want to go back to the stock FICM code I don't have any other suggestions.
Mark
Former
post #7 of 9 (permalink) Old 10-17-2017, 09:15 PM Thread Starter
JoeD7.3's Avatar
I already had them send me out a new module to set it back to stock. I couldn't see how it'd affect it as its only tuned inside the FICM
JoeD7.3 is offline
post #8 of 9 (permalink) Old 10-25-2017, 07:44 PM Thread Starter
JoeD7.3's Avatar
Mark i Still have not gotten the FICM TUNER back yet, but i removed the EPC solenoid i place in the 3-5 shift area and now its out of limp mode and has a the flare again. Could the solenoid be defective ? I know many people have done this without issue. However tomorrow i am taking it to work and reseting the ficm to stock with the IDS.
JoeD7.3 is offline
post #9 of 9 (permalink) Old 10-25-2017, 09:01 PM
My Photos: (6)
The EPC solenoid is not the same as the other solenoids. I have no idea what happens if you use an EPC solenoid in one of the other locations.
Mark
Former
