'00 7.3L Van crank-no start - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 02-08-2019, 07:01 PM Thread Starter
Alaskapsdvan's Avatar
My Photos: (35)
Unhappy '00 7.3L Van crank-no start
Time for me to have another crank but no start and remember it is in a Van.........
CPS changed and getting ready to check the fuel pump.
Question , key on and pump sounds like it is getting the fuel up to pressure and then it stops as it should. If one is out front it sounds like it is losing pressure,, is that right?
Update, fuel pump is pumping fuel. Going to put a charger on the batteries, they are still up but would like to top them off and try again Saturday as the sun is setting.
Also the superchips programer that I use does have a code reader to a point but there are no codes ..
2000 E350 7.3PSD, Hellwig Stablizer bar, 1.5"spacers from old Correct track OR,140 Lightforce with covers, 5x7 LED's From Truck-lite, extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E, My Photos
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline
post #2 of 10 (permalink) Old 02-08-2019, 08:12 PM
ArcticDriver's Avatar
Are you disconnecting the programmer and back to stock?
Are you plugging the block in overnight? Every little bit of increased temp helps.
SOLD:
ArcticDriver is offline
post #3 of 10 (permalink) Old 02-08-2019, 08:26 PM Thread Starter
My Photos: (35)
Will plug the block heater in the am, letting the battery charger have its way for now.
Been in the upper 20's to day and until yesterday there has no challenges to speak of other than the front elbow of the oil cooler blowing seals...
that you perceive
the web they weave
post #4 of 10 (permalink) Old 02-08-2019, 09:47 PM
jleedog's Avatar
You should probably start a new thread with your issues. You are posting on a real old thread that some people may no longer be looking at.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #5 of 10 (permalink) Old 02-09-2019, 04:33 PM Thread Starter
My Photos: (35)
For now here is the latest and greatest.
Over night charger and then for 1.5 hours the block heater.
Removed programing and returned to stock.
It fired up and is running.
Tomorrow will try starting with out the charger or the block heater.
that you perceive
the web they weave
post #6 of 10 (permalink) Old 02-10-2019, 05:07 PM Thread Starter
My Photos: (35)
Report of Sunday the 10th
Tried to start and it did not start.
Plugged it in and 2 hours later it did.
Looking for the relay.
Digging to the relay on the van is a pain in the seat so I am going to have one on hand when I dig into test.
Bad or not it is coming out.
Replaced it 5/13 so near 6 years of Alaskan winters.
that you perceive
the web they weave
post #7 of 10 (permalink) Old 02-10-2019, 05:25 PM
klhansen's Avatar
My Photos: (180)
Did you get 6 years out of a stock GPR? If so, you probably get the prize for GPR longevity (at least North of the 35th Parallel).
The Stancor relay I have in is still chugging along. Given the confines of the Van engine compartment, I'd definitely go with a Stancor replacement.
), AIS,
regulated return,
klhansen is offline
post #8 of 10 (permalink) Old 02-10-2019, 06:02 PM
Billium's Avatar
I got about the same from my Stancor. I replaced it, but I think I have other problems.
F250 Lariat 2001 Super Crew Henry Ford Black 7.3L 4x4
Billium is offline
post #9 of 10 (permalink) Old 02-10-2019, 08:18 PM Thread Starter
My Photos: (35)
It is a Stencor or White Rodgers, it went in June of 13.
I am hoping that it is not the plugs..... that will be a real pain in the back side.
But if I need to work on the turbo it is Right There all in the open.
that you perceive
the web they weave
post #10 of 10 (permalink) Old 02-15-2019, 06:04 PM
Absolute's Avatar
Wow, never knew there was a contest on. I have my original 02 GPR, its never given me trouble. Glow plugs are another story, but the GPR has been mint. 238k miles. It gets used here too, not as much as Alaska, but every day in winter.
Absolute is offline
Similar Threads
My 7.3L won't start or even crank over atropine '99 & up 7.3L Power Stroke Engine and Drivetrain 50 01-03-2018 08:52 AM
1999 F550 7.3L turbo will crank, won't start, will start with starting fluid. PLEASE HELP onethatuno '99 & up 7.3L Power Stroke Engine and Drivetrain 5 02-15-2015 03:10 AM
'02 F250 7.3L Crank, No Start ScubaTX '99 & up 7.3L Power Stroke Engine and Drivetrain 5 02-01-2015 12:45 PM
Need help soon...? fishmanwill Power Strokes 1994-1997 General 11 06-02-2006 07:24 AM
Van Stalls and will not start for over 1/2 an hour will not stay running HO0k3R E-Series Vans 2 05-08-2005 02:16 AM
