01 7.3 hpop crossover - Diesel Forum - TheDieselStop.com
 3Likes
  • 2 Post By bugman
  • 1 Post By Flounder_Pounder
post #1 of 10 (permalink) Old 08-01-2019, 09:30 PM Thread Starter
Hi everyone I'm looking into changing out the old cross over lines. I'm going to have them made at my local hydraulic shop with a hose rated at 5800psi and 23000 burst. Dose anyone know the hose lengths and fitting sizes. I'm trying to avoid taking them off and bringing them there. Thanks
Rdoc315 is offline
post #2 of 10 (permalink) Old 08-02-2019, 09:30 AM
I had a '99 way back that I installed a hydraulic hose from one of the suppliers on this forum don't remember who, it lasted a while then burst. I have another truck now that I installed riffraff's hard line crossover and it is very nice. Don't know that i'd use another soft line. fwiw.
Marcela is offline
post #3 of 10 (permalink) Old 08-02-2019, 11:34 AM
2000F250-7.3's Avatar
What Marcela said above the soft line will burst at some point buy a hard line worth the pice of mind.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #4 of 10 (permalink) Old 08-02-2019, 05:15 PM Thread Starter
Rdoc315 is offline
post #5 of 10 (permalink) Old 08-02-2019, 08:23 PM
bugman's Avatar
My Photos: (12)
If I were to do it again I wouldn't.
I noticed zero that is 0 difference from when I didn't have one to when I had one.
bugman is offline
post #6 of 10 (permalink) Old 08-03-2019, 11:59 AM
Texkenusmc's Avatar
Same here I have installed them on two 7.3s and saw no change. So did not mess with it on the one I have now
Texkenusmc is offline
post #7 of 10 (permalink) Old 08-06-2019, 07:35 AM
Rickie's Avatar
I would remove the hoses and lines and reinstall the plugs.
I made my own with Aeroquip hoses and fittings. We had their system where I used to work. I never saw one iota of difference when I added the hose or after I took them off. They were a little bit in the way when I replaced my HPOP O-rings.
Of course that does not answer the question you asked, but my hoses lasted from 2001 until 2012 or 2013 when I removed them.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
post #8 of 10 (permalink) Old 08-07-2019, 09:23 AM
ArcticDriver's Avatar
Good feedback here. This upgrade has always been on my “wish list” until now.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #9 of 10 (permalink) Old 08-07-2019, 09:41 AM
bugman's Avatar
My Photos: (12)
The theory behind it is a good one but when I did mine over 20 years ago owners were saying how much it quieted down the engine and helped everything associated with it.
When I put it on I didn't notice anything beneficial about it. Now perhaps if you placed a gauge on the back high pressure plugs before and after and came up with some actual readings you may be able to justify it.
It is a cheap mod and if you notice any difference I wouldn't call you out on it. It is just that I didn't.
As for those thinking of building one because they have access to the materials just remember that you have to deal with heat along with pressure, and the last thing that you want to happen while driving down the road is for it to let loose and cover the engine compartment with a couple of gallons of oil before the engine shuts down.
Rickie and ArcticDriver like this.
bugman is offline
post #10 of 10 (permalink) Old 08-27-2019, 11:10 PM
Quieted mine...
panhead george likes this.
1999.5 F350 4X4 CC 7.3 LWB 2" SuperLift, AIS, Gooseneck Hitch, Zoodad, South Texas Outfitters Bumpers, Autoenginuity, 295/75/16 Toyo AT/II's American Eagle wheels, 4 gauge overhead
2002 F250 2X4 CC SWB (Wife's) Stock except for AIS filter and Gooseneck Hitch
Flounder_Pounder is offline
« Loud | Rough Ideal »
