#19 Fuse Blows, DTC P1139, P0381 - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-26-2009, 08:02 PM Thread Starter
My 99.5 F350 PSD is blowing #19 fuse. Cluster goes dead and occasionally, the truck will not go into gear,despite that the column shift is in gear. As well as the door locks clicking like they are possessed.
Pulling P1139 & P0381 on the diagnostic tool of the Superchips Tuner.
Thnx.
Pikeintheweeds is offline
post #2 of 7 (permalink) Old 10-26-2009, 08:09 PM
P0381 Glow Plug Indicator Circuit Malfunction
P1139 Water in Fuel Indicator Circuit Malfunction
Not sure why
2002 Quad Cab/ Short bed/ BTS Auto/ Ford AIS Intake/ BTS 6 Pos. chip/ DI boost relief valve/ 4in DP no muff all the way back/ Bob's IC boots/ Bob's A/C bypass valve/ Bob's coolant/tranny filter/ 3 Yellow Tops Optimas under the hood/ HID's/ Switched GP's/ And a Really big wish list!
pilot4life is offline
post #3 of 7 (permalink) Old 10-26-2009, 08:18 PM Thread Starter
Yes,,,thnx for the code descripts, I was aware of them,,,but my question is why?
It only happens when I shift into or out of park. Shift column wiring harness ?
post #4 of 7 (permalink) Old 10-26-2009, 08:39 PM
woodnthings8's Avatar
Yes, the harness is grounding out through a worn spot in the wire. Look at the clockspring area.
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #5 of 7 (permalink) Old 10-26-2009, 08:50 PM
Just trying to help...someone may know the solution but may have not recognized the code without the description.
post #6 of 7 (permalink) Old 10-26-2009, 08:51 PM
Where is the clock spring at?
post #7 of 7 (permalink) Old 10-26-2009, 09:08 PM
underneath the airbag. Start pulling all the steering column covers off, to see if you can find the bad wire first.
Ken
