1999 6 Speed F250 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 10-06-2013, 05:53 PM Thread Starter
1999 6 Speed F250
Hello. Does any one know how I can find out production numbers for 6 speed F-250 7.3L in 1999? Thank you.
hapomykal is offline
post #2 of 6 (permalink) Old 10-06-2013, 07:02 PM
what do you mean?
timmyboy76 is offline
post #3 of 6 (permalink) Old 10-06-2013, 07:36 PM
klhansen's Avatar
My Photos: (180)
Not very many.
Hard to find in that model year, and even harder for '11 and up (no manual trannies ).
I'd guess that it was less than 1 for each 5 auto tranny trucks produced.
To find real production numbers, you might PM FordService here on TDS. They may have access to the figures.
), AIS,
regulated return,
klhansen is offline
post #4 of 6 (permalink) Old 01-06-2019, 10:45 PM
Looking for a diagram of the linkage for a 6 speed manual transmission. This is on a F 250 7.3
Ladywireman is offline
post #5 of 6 (permalink) Old 01-09-2019, 02:16 PM
Ladywireman, there is no linkage for the transmission. The shifter bolts directly to the transmission and all the moving parts, shift forks, etc are internal to the transmission. The clutch is hydraulic with a clutch master cylinder and a slave cylinder.
2000 F350 DRW 7.3
tomlin is offline
post #6 of 6 (permalink) Old 01-09-2019, 02:42 PM
There is no linkage on these trucks. The clutch is hydraulic and easy to trace from pedal to transmission housing
Buffalohead1 is offline
