2000 7.3 liter won’t start - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 06-26-2019, 06:04 AM Thread Starter
ERIC6714's Avatar
Hey guys I pulled my 2000 f-350 in my garage 2 weeks ago. It was running fine. Went out to use it and it won’t start. It cranks fine but will not even hit a lick . I thought I would see what you guys thought before I check it out. I was thinking crank or cam sensor. Any ideals?
Thanks Eric
ERIC6714 is offline
post #2 of 18 (permalink) Old 06-26-2019, 07:11 AM
RT
RT's Avatar
Never a bad place to start. Do you have any type of scanner?
RT is offline
post #3 of 18 (permalink) Old 06-26-2019, 09:51 AM Thread Starter
ERIC6714's Avatar
Yes I do just haven’t had a chance to hook it up yet.
ERIC6714 is offline
post #4 of 18 (permalink) Old 06-26-2019, 01:03 PM
ArcticDriver's Avatar
Did you happen to check the voltage after it sat for a couple weeks?
SOLD:
ArcticDriver is offline
post #5 of 18 (permalink) Old 06-26-2019, 05:34 PM Thread Starter
ERIC6714's Avatar
I had to charge my batteries they ran down. There about 3 yrs old. After I got them charged I cranked and cranked won’t hit a lick.
ERIC6714 is offline
post #6 of 18 (permalink) Old 06-26-2019, 08:21 PM Thread Starter
ERIC6714's Avatar
My tachometer is moving when I crank it so that rules out a crankshaft sensor doesn’t it.
ERIC6714 is offline
post #7 of 18 (permalink) Old 06-26-2019, 09:17 PM
klhansen's Avatar
My Photos: (180)
What lights on the instrument panel light up when you turn the key on?
Have you checked all the fuses?
Can you hear the fuel pump run when you turn the key on?
), AIS,
regulated return,
klhansen is offline
post #8 of 18 (permalink) Old 06-27-2019, 05:57 AM Thread Starter
ERIC6714's Avatar
Yes the fuel pump is running. Water in fuel comes on but goes off when you crank. All the regular ones come on battery oil etc. the funny thing it won’t even attempt to start.
ERIC6714 is offline
post #9 of 18 (permalink) Old 06-27-2019, 11:49 AM
2000F250-7.3's Avatar
Does the wait to start light come on check your oil level check for fuel in the bowl. See what your icp and ipr value are wile cranking.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #10 of 18 (permalink) Old 06-28-2019, 01:20 PM Thread Starter
ERIC6714's Avatar
Update
I have plenty of oil in the engine there is fuel in the bowl and doesn’t look like any water. I plugged up my block heater for 3 hrs. Still won’t start it acts like it isn’t getting any diesel. I hooked my code reader to it I have a Autel code reader and it’s says no codes are present. I am thinking the IPR valve or the HPOP. Wouldn’t it be throwing a code if the IPR was bad?? What is a good code reader for a 7.3 liter? Any help would be appreciated Eric
ERIC6714 is offline
post #11 of 18 (permalink) Old 06-28-2019, 01:59 PM Thread Starter
ERIC6714's Avatar
I unplugged my icp sensor it defaults if you unplug it but it still wouldn’t start.
ERIC6714 is offline
post #12 of 18 (permalink) Old 06-28-2019, 04:50 PM
klhansen's Avatar
My Photos: (180)
Check to see if the coil on the IPR has fallen off. If so, it won't build any HP oil pressure and the PCM won't know that the IPR isn't actually doing anything, just that there's no HP oil pressure sensed by the ICP sensor.
AutoEnguinity is a good tool to have. If your code reader can be set up to monitor parameters (AutoEnginuity can), look at ICP, IPR Duty Cycle, Engine RPM, Battery voltage and Injector Pulse Width while cranking. Post what you find out on those parameters
), AIS,
regulated return,
klhansen is offline
post #13 of 18 (permalink) Old 06-29-2019, 07:50 AM Thread Starter
ERIC6714's Avatar
The coil is still on the IPR. I’m going to go ahead and replace the IPR the Icp and the camshaft sensor. There is some oil on the icp connector. My tach is moving when I crank it but you can find everything on amazon pretty cheap.
ERIC6714 is offline
post #14 of 18 (permalink) Old 06-29-2019, 11:42 AM
klhansen's Avatar
My Photos: (180)
Originally Posted by ERIC6714 View Post
Iím going to go ahead and replace the IPR the Icp and the camshaft sensor. There is some oil on the icp connector. My tach is moving when I crank it but you can find everything on amazon pretty cheap.
OK, but you'll probably spend as much as you would on AutoEnginuity, which you would then have to use forever to find the ACTUAL problem. Although oil on the ICP connector is a sign that it either is or will soon be unserviceable.
Some guys have had issues with cheapo IPRs, so be aware that they might not be the best value.
), AIS,
regulated return,
klhansen is offline
post #15 of 18 (permalink) Old 06-29-2019, 01:26 PM
Make sure your batteries are fully charged in the meantime. Low batteries and a failing starter can draw so many amps the injectors don't fire properly.
DENNY
EDIT; OOPS missed that you charged batteries, check the fuze for the fuel heater in the fuel bowl.
DENNY is offline
