2000 f250 7.3 just clicks - Page 2 - Diesel Forum - TheDieselStop.com
 5Likes
post #16 of 35 (permalink) Old 01-16-2019, 09:12 AM
Absolute's Avatar
Yours is different than mine, so I'm not totally sure. Mine has no relay on the fender. So, since you have the relay Id guess your trying to bypass that. If you provide 12v to the little wire, all it does is turn the starter on, and activates the solenoid to pop the gear out. All the power is provide by the big wire. On mine the big wire goes straight from the battery to the starter, no relay involved, and the little wire is controlled by a relay in the fuse box. I would think your big wire is attached to the relay on the fender. If it is, then to properly test the starter you would need to supply a power wire from the battery straight to the large lug on the starter.(take the relay one off and move it to the battery, don't use both) Then to activate the starter you need to provide 12v to the little wire. Once the relay on the fender is bypassed, you could just activate the small wire by clipping a short jumper from the big lug on starter to the little lug on the small wire. Or straight from the battery. But since you say the starter click, Id just provide the 12v to the big lug bypassing the relay, then just use your key to activate the little wire. Its clearly functioning if it clicks when your turn your key. AS said my system is a bit different, so might want to confirm all that. lol
Absolute is offline
post #17 of 35 (permalink) Old 01-16-2019, 09:38 AM
At this point I would just pop the starter off and see what it does on the floor. 10 15 mins can have the starter off. use jumper cables to the starter then jump from little terminal to the larger power one. Clicks bad starter, works problems elsewhere.
Randy 4614 is offline
post #18 of 35 (permalink) Old 01-16-2019, 10:11 AM
Absolute's Avatar
Unfortunately, this is not the case. Do not rely on this test!! As with my recent starter replacement. It worked great on the bench. But didn't have enough torque to turn the motor. So the click is the solenoid pop, then nothing could be dead motor, but also can be too weak a motor, like mine. Proper bench testing requires a load on the motor.
Randy 4614 likes this.
Absolute is offline
post #19 of 35 (permalink) Old 01-16-2019, 10:30 AM
The point is you will know if the solenoid on the starter is engaging the starter and making it spin. Totally agree a load test is the only real way to test one, which parts stores can't do. In this case being he can't reach the little wire he should drop the starter hookup up a wire set it back up and try it that way.
Sent from my SAMSUNG-SM-J327A using Tapatalk
post #20 of 35 (permalink) Old 01-16-2019, 11:08 AM
Absolute's Avatar
Respect your opinion, but if it spins , hes off on a wild goose chase because he will assume its fine. Id guess at least 50% of failed starters are from weak motors, not total failure. Also, my post before explained he need only MOVE the positive wire from the relay to the battery terminal. No need to put your hand on the starter. He already stated cleaning the terminal on the NEW starter, so its not a factor. Unless his positive wire is bad. Also, he said hes using the key to fire it, and it clicks. So solenoid is being activated, whether its working or not. So no need to put your hand on the starter there either. Simply move the positive from the relay to the battery. Try the key. If it clicks, the motor is dead or too weak to start. If it starts, the relay is broke. All assuming batteries are 100%
Absolute is offline
post #21 of 35 (permalink) Old 01-16-2019, 11:26 AM
Just went through something like this on my 99 Powerstroke. Six month old nap a starter turn the key on to start it would click but it wouldn't start. Jumped both large terminals at the starter and it would crank over. Pulled the starter and tested it on the ground the solenoid would not engage. Took it back got a brand new starter everything work just fine. But these diesels one has to be a little mechanically inclined to work on them or just pull them to a shop. I would say that the majority of the no starts on them are bad starters. One reason why to spend good money and buy a good starter for them. I'm learning that Napa starters don't fall into the category of good starters.
post #22 of 35 (permalink) Old 01-16-2019, 11:35 AM
Absolute's Avatar
If the solenoid is gone, then the motor spins , but the engine doesn't. In my opinion. Get the Denso starter. It barely fits in there, I had to grind 1/4 inch off the frame to fit mine. It also uses all 3 bolts. Common for the 2 bolts to come loose. 3 hold better and that ensures the ground is secure. It of course costs more. But well worth it when you hear how fast your motor spins up with the torque the Denso has. Everything at Napa is made in China. Just saying.
Absolute is offline
post #23 of 35 (permalink) Old 01-16-2019, 12:58 PM
klhansen's Avatar
My Photos: (180)
Originally Posted by Jake7.3/6.7 View Post
Auto zone I couldn’t reach the little one with a jumper do I need to have the battery cable on the big positive before I try to jump the little wire
How long were the jumper cables they tried to use? 6 inches? It's only about a foot from the passenger side battery positive terminal to the small terminal on the starter relay. Or it's about 2 inches from the hot terminal on the relay over to the small terminal.
), AIS,
regulated return,
klhansen is offline
post #24 of 35 (permalink) Old 01-16-2019, 02:37 PM
It sounds to me as if it wasn't exactly clear to the OP exactly from where to where he was supposed to jump. Maybe he was trying to jump from the battery terminal down to the starter, and the cables weren't long enough, or possibly there wasn't clearance and the battery cable terminals couldn't fit into where he was trying to put them. Maybe with a clearer explanation he can understand exactly from where to where he is supposed to jump.
DonWarkentin is offline
post #25 of 35 (permalink) Old 01-16-2019, 03:49 PM
79jasper's Avatar
That's not how this works......
You would be hard pressed to find a setup that uses a single wire starter, like you assume the "relay on the fender" style works. (Since the early 80's, no Ford diesel ever had one either)
A. Starter always has constant power directly off the battery.
B. The wire coming from the fender relay to the starter is just the "start wire." For whatever reason (I'm guessing amp draw) Ford ran the start wire through that fender relay on the older trucks. No different than how yours works with the relay in the fuse box.
Sent from my SM-N960U using Tapatalk
79jasper is offline
post #26 of 35 (permalink) Old 01-16-2019, 04:21 PM
klhansen's Avatar
My Photos: (180)
Don
You're exactly right. But you'd think that a parts store counter guy would have some understanding of starting circuits.
To the OP: To test the starter relay on the fender, jumper 12V to the small terminal on the relay. It should pull in and send power to the small terminal on the starter solenoid mounted on the starter. If it still doesn't crank over, then you need to test the starter solenoid itself. Do that by jumpering 12V to the small terminal on the starter solenoid (a little hard to get at, as it's up by the crossmember and above the starter). There will be constant 12V at the large cable terminal on the starter as 79 Jasper explained, so you can jump from that terminal to the small terminal on the starter solenoid.
), AIS,
regulated return,
klhansen is offline
post #27 of 35 (permalink) Old 01-16-2019, 06:12 PM
blue99stroker's Avatar
Have you lifted up the shifter handle or tried to start in neutral?
The shifter alignment could be off causing this very thing.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #28 of 35 (permalink) Old 01-16-2019, 06:18 PM
Calico5's Avatar
You kids today...
Nobody remembers how to stick an old screw driver across the terminals to bump a starter?
C'mon!
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #29 of 35 (permalink) Old 01-16-2019, 06:21 PM
Calico5's Avatar
Neutral-start switch interrupts the circuit between the key switch and the fender relay. If the neutral-start switch were open, he wouldn't be getting a "click"...
Al in SoCal
Calico5 is offline
post #30 of 35 (permalink) Old 01-16-2019, 06:56 PM Thread Starter
Jake7.3/6.7's Avatar
I appreciate everyone help yes I used a 12 in 2 gauge jumper wire that was for a plow solenoid to the fender relay and got a click I then used a voltage meter to make sure I was getting power at the constant (big wire) at the starter I was getting 12.58 at the starter I then jumped the big wire at the starter to the small terminal and I just got a click then I went ahead and redone the battery terminals and cutting about a inch off each side of the wiring on the battery lines to clear from the corrosion on them and then added lugs to connect to terminals after that checked again and just clicked I hooked both batteries to both batteries on my Cummins with it turned on and again starter just clicked I checked number 20 fuse like suggested and it tested good so I went ahead and replaced it anyway still just clicked so I went ahead and took the starter off and took to autozone starter tested good asked them to give me a new one because it’s under warranty and won’t work under load I cleaned up the area bolts to and i assume is the spot it grounds itself so I went at it with a wire brush untill it was clean installed new starter and fired right up end result autozone starters suck
Jake7.3/6.7 is offline
