$2000 HPOP - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 05-11-2017, 08:31 AM Thread Starter
$2000 HPOP
Hello, I have a 2002 F350 7.3 ambulance. Was driving great the other day, then suddenly check engine light came on and loss of power. This is a daily work truck and it is my busy season. I made it to my next two jobs, then had vitually 0 power. It would crank, no bad noises, but RPMs would not crawl up at all. Had it towed to the dealership and they are saying I need a new High Pressure Oil Pump for a total of $2000. Seems steep for the job, but it's costing me money not having it on the road. Are there any other questions I should be asking such as what else they are replacing, etc?
Thanks!
Remoteproductions is offline
post #2 of 8 (permalink) Old 05-11-2017, 09:10 AM
RT
RT's Avatar
I'd ask how they diagnosed the HPOP. That's a little abrupt given it is one of the most reliable components in the system. The IPR valve is more often the culprit when you can't build pressure. It could also be a downstream leak (like a ruptured injector o-ring) or an upstream feed issue (like a bad low pressure pump or cracked pick up tube).
To condemn the HPOP, they would need to have done a block off pressure test on both sides of the pump with a known good IPR- ask for those values.
RT is offline
post #3 of 8 (permalink) Old 05-11-2017, 11:18 AM
2000 dollars hpop cosy round 500 so 1500 in labor that's high. To be honest anyone can change the hpop it's not the biggest job out there. But I do agree with @RT I would ask for the diagnostic sheet with numbers of everything. On 7.3 the hpop is usually not the problem unless you have long overdue oil changes that what kill a fleet truck that I took maintenance on they got a fleet of 10 and all get 15w40 (4 are gas burners rest diesel) and all get a 7k to 8k oil change
Sent from my SAMSUNG-SM-G870A using Tapatalk
rustygold is offline
post #4 of 8 (permalink) Old 05-11-2017, 12:12 PM
blue99stroker's Avatar
Could even be a failed Icp. Unplug it and try and start
I agree with other guys. I doubt it just failed.
blue99stroker is offline
post #5 of 8 (permalink) Old 05-11-2017, 01:03 PM
This is exactly why I bought a scanguage II. I monitor my vitals while driving including the ICP pressures, IPR duty cycle and many other items. If some thing is wrong with the IPOP it will show so If I get caught on the road and have to be towed at least I will have a pretty good idea of the problem before they give an estimate. Does not take much room on the dash.
2002 F250 Stock PSD Crew Cab SRW
1998 HR Endeavor MH w/275 Cummins Diesel and MD3060 Allison 6 speed
PREVIOUS TRUCK 97 F250 PSD 3.55 Draw-Tite Slider, pulling 2850RK Keystone Montana DIY Exhaust brake with TC Lockup
redtopman is offline
post #6 of 8 (permalink) Old 05-11-2017, 04:58 PM
klhansen's Avatar
My Photos: (180)
I wouldn't doubt a quote of $2000 for replacing an HPOP. Autonation WBL sells a reman for $644, with a list of $837, and what dealer gives you a discount on parts they install? I just R&R'd mine to fix a blown out "non-serviceable" plug o-ring (replaced all the o-rings on the HPOP except the rear cover, just to be sure). I think I was at it for at least 8 hours, but again, I'm getting old and decrepit , so take that with a grain of salt. But at the prevailing dealer labor rates, I wouldn't doubt the $2000 quote.
But like everyone else said, it's VERY LIKELY NOT the HPOP, but some other component causing your problem.
), AIS,
regulated return,
klhansen is offline
post #7 of 8 (permalink) Old 05-11-2017, 08:35 PM
Happy to hear that some other forum members are old and decrepit like me.
post #8 of 8 (permalink) Old 05-13-2017, 07:57 AM
greenskeeper79's Avatar
post a video of the truck starting, idling, and giving it the pedal.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6 E99 CALI DELETE
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper79 is offline
