2002 7.3 Fuel Filter Housing Cap Leaking - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 10-08-2006, 03:05 PM Thread Starter
I have replaced my fuel filter and have followed the instructions. I have coated the O-ring and the housing seal with diesel and tightened it down so that it won't go any more. After a day of running it I was able to tighten it down a bit more. It is still leaking! Does anyone have a "procedure" for installing these fuel filters/caps that works? Please Help.
tmelland is offline
post #2 of 16 (permalink) Old 10-08-2006, 03:52 PM
Re: 2002 7.3 Fuel Filter Housing Cap Leaking
I had asimilar problem a year ago. It turned out that my cap had a hairline crack in it which was very hard to see. I replaced the cap and have had no roblem since. If you can, don't buy the cap from the dealership, I didn't have that luxury, and they got me for $54. I believe Napa carry's them and some of the sponsors of this site.
Early '99 F350 SRW.3:73 Gears DP Tuner Chip,AFE MAGNUM FORCE AIR INTAKE,FORD REPLACEMENT TORQUE CONVERTER, REMOTE START, NEW Delphi CPS, Ford Blue CPS as SPARE ,BLACKCLOUD DIESEL HX OIL LINE.
pandersen is offline
post #3 of 16 (permalink) Old 10-08-2006, 07:07 PM
Ran440's Avatar
Still using the factory original cap.
Randy
1999 ( Build date 10/98 ) 1-Owner F-250 XLT PSD, XLE8 ( started out as XLE4 ), Auto Trans w/sonnax valve tricumulator springs, 4x4, manual hubs, manual shift transfer, 3.73 gears, Tymar intake, open air CCV, A-pillar 3 gauge W/Auto Meter pyro, boost, trans and axle temp in Mag-Hytec covers, Banks 4" monster exhaust, DI 4 Position Flip Chip stock-75-100-110, early 99 turbo conversion W/ ATS BB Turbo, gutted EBPV, Smitybuilt bumper guard, Lund bug deflector, Lund SS cold air grill guard, Wet Okole seat covers w/Powerstroke logo, custom made floor mats ( way better than any store bought mats )
Buy American, Keep Your Job.
Ran440 is offline
post #4 of 16 (permalink) Old 10-08-2006, 07:23 PM Thread Starter
No...I bought an after market cap from NAPA.
tmelland is offline
post #5 of 16 (permalink) Old 10-08-2006, 09:38 PM
My Photos: (9)
check to make sure the O-Ring is on the filter cap. Then check to make sure it is installed correctly. the O-Ring is tapered to fit in the groove of the fuel bowl. if you have installed this O-Ring Upside down it will leak every time.
Also make sure that your fuel bowl is not cracked,because the tighter you think you are getting the cap, the farther apart the sides of the crack in the bowl become, and the more fuel you will leak.
bdrummonds is offline
post #6 of 16 (permalink) Old 10-09-2006, 02:34 AM
Last time I changes mine I had to put a great deal of torque on the cap to stop it from spraying fuel. I also found out that the gasket must be on there exactly right.
Larry
02 F250XLT SD CC LB 4X4, Silver, SD Air Lifts, 4R100, Westin Sportsman grill/brushguard, Leer Shell, AIS Severe Duty w/added fender intake, Edge EVO running 80 HP, ISSPRO's w/cubby mount, Rancho 9000X's, Banks 3 1/2" downpipe, BTM, 3 1/2" exhaust front to rear with 5" stainless tip. Sonnex and Tricum's. Fumoto Valve. Royal Purple ATF. Tru-Cool 4590. Tekonisha Prodigy. SP Diesel SSEBTC Exhaust Brake. Like new 88 Vacationeer 11.4' or 2008 Cardinal 31SB, 1992 Bayliner Trophy and the itch to go, baited hooks and the need to fish, loaded guns and the need to hunt.
Larry P is offline
post #7 of 16 (permalink) Old 10-09-2006, 12:27 PM Thread Starter
This all started when I discovered a small diesel leak underneath the truck. It was the factory filter cannister cap with the factory fuel filter element leaking from where the cap meets the cannister.. I decided I would replace the filter element along with the cannister cap which included a new O-ring for the element and a new gasket for the cannister cap. I went to NAPA and purchased the element and the cap. ( seperate items, there is a element/cap all in one out there). The cannister cap has threads on it that are used to "align" the cap to the cannister lip which is really a small surface area for the cap to align with. The NAPA filter that I bought had such sloppy threads on the lid that it allowed the lid to sit off to one side when tightening it down. THIS is the lid that has the nut incorporated into the lid so you can get a 1" socket on it. When tightening the lid down, it will want to go off center every time. I went outside this morning to go to work and just turned on the key to the truck and smelled diesel fuel. I exited the truck and looked underneath and the diesel was pouring out the bottom of the truck and spraying out the lid. [img]/ubbthreads/images/graemlins/mad.gif[/img] I ended up putting the original lid back on with new O-ring and lid gasket (flat side of LID gasket down on cannister edge) and so far so good as of this morning. The only challenge with the factory lid is getting something on there to tighten it sufficiently. I used fully extended channel locks to grap the segments in the lid and it seems to have seated alright. Thanks everyone for their input and I hope this helps someone...don't buy the NAPA lid with the nut incorporated on the lid! Sloppy threads = massive fuel leaks! [img]/ubbthreads/images/graemlins/grin.gif[/img]
tmelland is offline
post #8 of 16 (permalink) Old 10-09-2006, 12:36 PM
I change my fuel filter every time I change the oil. Every 5K miles. As far as tightening... I use the fully extended channel locks, but I don't use the jaws. I stick the the handle in the cap and tighten. Once I used another pair of pliers to grasp the channel locks, but usually I can get it tight enough with one channel locks.
jpmueller is offline
post #9 of 16 (permalink) Old 10-09-2006, 12:43 PM
My Photos: (9)
The PowerStroke Shop Has a really nifty tool for the fuel filter covers...might be worth looking at
Here is a link to the tool directly..
Fever is offline
post #10 of 16 (permalink) Old 10-09-2006, 08:56 PM
I have the factory cap still .No leaks on eithe truck. I always use the oil filter wrench. It fits perfectly.
2002 Lariat C/C L/B 4X4 6speed
banks power pack
2005 Alfa toyhouse
1947 Willys CJ2A toy
1999 XLT C/C L/B 4X4 6 speed (stolen)
cattywampus is offline
post #11 of 16 (permalink) Old 10-10-2006, 06:35 AM
To each his own but changing the fuel filter every 5K seems a bit extreme, and expensive. I've never changed mine in less than 15K and never had a problem with 2 different trucks.
Larry [img]/ubbthreads/images/graemlins/cool.gif[/img]
Larry P is offline
post #12 of 16 (permalink) Old 10-10-2006, 11:41 AM Thread Starter
What type of oil filter wrench are you using? The band type? It would seem difficult to get the band type oil filter wrench in the space provided. Let me know.
tmelland is offline
post #13 of 16 (permalink) Old 10-10-2006, 06:47 PM
It's a band type with a swivel handle.
banks power pack
2005 Alfa toyhouse
post #14 of 16 (permalink) Old 09-17-2019, 12:36 PM
Thanks for this thread... replaced my drain valve o-rings and must have flipped the triangle profile o-ring upside down.
Fuel leaking everywhere around the top. Watching near the end of Ford Tech Malluco’s(?) video on 7.3 fuel filter service, he shows that the largest flat face goes down on the bowl in the “channel” around the inside of the rim, and the steep bevel on top, should be inward toward the filter, and the shallower sloped bevel outward.
Hope that info helps anyone doing their first filter change on one of these, or someone like me, who got it right on the filter change but forgot the orientation and didn’t look close enough when taking it off to work on other issues.
OrCoast7.3 is offline
post #15 of 16 (permalink) Old 09-17-2019, 02:30 PM
Tool is discontinued.
https://www.xtremediesel.com/alliant...ap-socket-tool
DonWarkentin is offline
