2002 7.3L Glow Plug Relay - Diesel Forum - TheDieselStop.com
post #1 of 31 (permalink) Old 12-30-2018, 01:10 PM Thread Starter
Decided to switch out my relay this morning. After swapping it out and trying to start it I saw smoke coming out. The power wire running from the GPR to the battery completely melted at the battery terminal?? I am sure that my wiring is correct, but have no idea why it melted? Any ideas on what might have caused this or how to fix it. The truck will turn over but will not start now... Looks like I am going to have to replace the entire wire from the battery to the GPR, or somehow splice it. TIA!
lj8215 is offline
post #2 of 31 (permalink) Old 12-30-2018, 02:11 PM
2000F250-7.3's Avatar
Picture of what happen and how it is hooked up would help.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #3 of 31 (permalink) Old 12-30-2018, 02:48 PM Thread Starter
Ok. Here are a few pics.
lj8215 is offline
post #4 of 31 (permalink) Old 12-30-2018, 03:50 PM
RT
RT's Avatar
What is the wire I have circled in red? It looks like a ground strap. The brown, yellow, and blue wires go on that terminal. Where does that other one lead to?
RT is offline
post #5 of 31 (permalink) Old 12-30-2018, 04:38 PM Thread Starter
The terminal you have circled is opposite the "hot" terminal with the battery connector. It has the yellow and blue wires attached. These are the only 2 wires that can go on that terminal due the larger size. The other terminals are very small with small guage wire and small connectors. The "hot" terminal is larger and goes directly to the battery, which is melted now...
lj8215 is offline
post #6 of 31 (permalink) Old 12-30-2018, 04:43 PM
ArcticDriver's Avatar
What is the P/N and brand of your new GPR? Can you take a photo of the box?
SOLD:
ArcticDriver is online now
post #7 of 31 (permalink) Old 12-30-2018, 05:01 PM Thread Starter
lj8215 is offline
post #8 of 31 (permalink) Old 12-30-2018, 05:23 PM
RT
RT's Avatar
I see the yellow and blue wires attached. There is also another wire attached which I took the time to circle in red. What is the wire circled in red? It looks like a ground strap.
Sent from my iPad using Tapatalk
RT is offline
post #9 of 31 (permalink) Old 12-30-2018, 05:31 PM Thread Starter
Sorry.. Yes, it is grounded to the mounting bolt below it.
lj8215 is offline
post #10 of 31 (permalink) Old 12-30-2018, 05:33 PM
RT
RT's Avatar
In the picture, it really looks like that ground strap is attached to the terminal. That would explain what happened.
RT is offline
post #11 of 31 (permalink) Old 12-30-2018, 05:35 PM
JJEdwards's Avatar
I don't know but could it be the new relay? I just replaced my GPR 2 weeks ago with a motorcraft from oreilly's and is working no problem.
JJEdwards is offline
post #12 of 31 (permalink) Old 12-30-2018, 05:41 PM
bugman's Avatar
My Photos: (12)
There should be nothing grounded to a mounting bolt off of the GPR.
You should have a hot wire from the battery, a key on hot wire, the wires to the glow plugs, and the signal wire from the PCM.
bugman is offline
post #13 of 31 (permalink) Old 12-30-2018, 05:45 PM Thread Starter
Crap.. I will pull it back off and take a look.
lj8215 is offline
post #14 of 31 (permalink) Old 12-30-2018, 05:56 PM Thread Starter
Ok. Good catch. The blue and yellow wire got pinched underneath the GPR when I installed the new one. A little electrical tape will fix those pretty easy. Any idea how to fix the power wire going to the battery??
lj8215 is offline
post #15 of 31 (permalink) Old 12-30-2018, 07:04 PM
bugman's Avatar
My Photos: (12)
You might try the dealer but as old as the truck is you might have to have one made
bugman is offline
