2002 F-250 7.3 oil leak help - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 01-23-2019, 06:21 PM Thread Starter
Texkenusmc's Avatar
On my truck I have an oil leak is coming on the drivers side that looks like it is coming from somewhere under the water pump. It is not coming from the top of the motor and is not the oil cooler. It not doing it under idea only when driving.
Texkenusmc is offline
post #2 of 15 (permalink) Old 01-23-2019, 07:30 PM
bugman's Avatar
My Photos: (12)
Front cover or the HPOP gasket. Or a number of other places that are hidden by all the accessories on these trucks.
I'd make sure that it isn't the high pressure oil gallery plug on the end of the head or one of the plugs on the high pressure oil system.
bugman is offline
post #3 of 15 (permalink) Old 01-23-2019, 10:50 PM Thread Starter
Texkenusmc's Avatar
Will try and take a better look in the next few days. Going to clean and pressure wash it the start looking again.
post #4 of 15 (permalink) Old 01-24-2019, 05:47 AM
https://deadheaddiesel.com/7.3-power...mon-oil-leaks/
Here is something that might be useful .
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 254,500 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #5 of 15 (permalink) Old 01-25-2019, 03:23 PM Thread Starter
Texkenusmc's Avatar
Thanks panhrad I will check them all tomorrow I know it is not the oil cooler or hypop lines they have all been replaced in the last year
post #6 of 15 (permalink) Old 01-25-2019, 04:17 PM
I also have a 2002 Ford F250 7.3 4x4.
Your leak could be coming from the oil pan itself or the seal between the oil pan and the engine block. These engines are notorious for oil pans rusting thru. If it is your oil pan, I recommend the Moroso Ford 7.3L Powerstroke oil pan.
Four months ago I had my engine pulled to replace the oil pan. While the engine was out I had the following preventative repairs made: exhaust manifolds pulled to replace the exhaust manifold bolts and gaskets; the oil cooler was rebuilt with new O-Rings and gaskets; replaced the rear main oil seal, pulled the injectors to replace all the injector cups; and replaced the oil dipstick tube and mount to the oil pan.
It was a total success. I no longer have any oil leaks.
Good luck! I know how hard it can be tracking down oil leaks.
powderhound12 is offline
post #7 of 15 (permalink) Old 01-25-2019, 06:13 PM Thread Starter
Texkenusmc's Avatar
It is not the oil pain I am thinking probably timing cover or bottom of hypop.
post #8 of 15 (permalink) Old 01-26-2019, 10:52 AM
I have a similar issue. I also replaced my pan and installed cnc fab oil lines last year.
post #9 of 15 (permalink) Old 01-26-2019, 11:22 AM
Calico5's Avatar
Any leakage from the HPOP will end up in the valley, and drain out the back of the block (at the valley drain hole), so it's not going to be the HPOP itself, or the face seal.
Also, there is no "behind the water pump", as the water pump itself is mounted directly into the front cover (the cover forms the back-side "volute" of the pump). However, a couple of the water pump bolts DO extend through/into the inside of the front cover (into the timing gear area). Maybe weeping coming from there? Doesn't seem likely, as there is no "pressure" there, but anything is possible.
Since your leakage is towards/on the front of the engine, it is possible that the HPOP reservoir lower seal/o-ring could be leaking (or the upper cover seal as well). This is above the water pump. They are readily visible, just looking over the fan shroud at the front of the engine.
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #10 of 15 (permalink) Old 01-27-2019, 07:00 PM
Absolute's Avatar
Any chance you had the dampener off? Its a leaker if you don't rtv the key slot.
Absolute is offline
post #11 of 15 (permalink) Old 02-05-2019, 11:30 PM Thread Starter
Texkenusmc's Avatar
The leak ended up being the oil cooler were it matters up to the block up front.
post #12 of 15 (permalink) Old 03-24-2019, 11:41 AM
Did you fix it yourself? Any details?
2002 F-250 PSD Super Cab Long Bed 3.73 LS... Stock!!
OBXNC is offline
post #13 of 15 (permalink) Old 03-24-2019, 12:30 PM Thread Starter
Texkenusmc's Avatar
Yes it is a little messie but not a bad job. It took me about 5 hours but I have had 7 back surgeries. Google oil cooler change on your year model and you will find videos on how to do it. That will help you a lot.
post #14 of 15 (permalink) Old 03-24-2019, 12:33 PM Thread Starter
Texkenusmc's Avatar
I am looking at buying a house in your neck of the woods OBXNC. Up by Sanford NC my son lives in Gastonia NC.
post #15 of 15 (permalink) Old 03-24-2019, 12:55 PM
Welcome to NC!! Sanford is a nice area... you can get to the coast or Gastonia with reasonable drives.
OBXNC is offline
