2002 F350 7.3L long crank start - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By jricherson
post #1 of 3 (permalink) Old 05-05-2017, 02:16 PM Thread Starter
Question 2002 F350 7.3L long crank start
Hello,
I have a 2002 F350 with 7.3 diesel that has a hard start problem. Glow plugs have been replaced. After glow plug light goes off, it will have to crank for at least 5 sec. before starting. After it is running, you can shut it off and it will start instantly. Let it sit for 2 Min. and try to start again, and it cranks for at least 5 sec. again before starting. I also notice a little shaking in motor for just a little bit and then it smooths out.
I have heard of O rings bad on Injectors loosing oil praesure, but have not had valve covers off to check that yet. Any other ideas before we have to go deep on taking apart? Steve
stangman6796 is offline
post #2 of 3 (permalink) Old 05-05-2017, 02:23 PM
jricherson's Avatar
My Photos: (14)
Welcome to the forum. Sounds like it could be a couple things but more diagnosis needed. You will get lots of good advice and suggestions.
My first guess is maybe the HPOP reservoir is maybe leaking back. You can take the plug out of the top and check oil level to see if dropped. Second could be to unplug the ICP and try it.
If you have someone close by with software (AutoEnginuity) to scan while trying to start will help. Others will give help here also.
stangman6796 likes this.
2001 F-250, 4X4, SWB, 7.3L, Crew Cab, MBRP 4" exhaust, Tymar intake, Swamps 175/146 single shot injectors, Driven Diesel Regulated Fuel Return, PHP Hydra Chip, Mechanical Waste Gate, Gutted EBPV, Deleted EBPV Pedestal, BTS tranny, 6.0L tranny cooler, RedHead steering box, Plenum inserts, RiffRaff upgraded clamps for intercooler boots, RiffRaff intake sleeves, CCV bypass from RiffRaff, boots from RiffRaff, Ride Rite Air Bags, Guzzle's Monster Relay mod, 1.0 A/R turbo Housing.
1996 F-250, 4x4, SWB, 7.3L, Supercab, Tymar, AFE Big Bore 4" exhaust with 3"-4" DP, Swamps 150/146 Injectors, PHP Hydra Chip with Swamps tunes, Terminator T500 HPOP, Beans D66 Turbo, HPX Crossover, EBPV gutted, EBPV Delete Pedestal, shimmed FPR, Carr Hoop Steps, Cab Lights, Limited Slip 4.10 rear end.
2002 F-250 4X4 Extended Cab Short Bed California truck, AFE 4" Exhaust, Tymar intake, Leveling Kit, Swamps 175/146 Single Shots, HydraChip with Swamps Tunes, Wicked Wheel, Mechanical Waste Gate, Gutted EBPV and deleted pedestal, RiffRaff intake sleeves, RiffRaff boots and clamps, BTS Transmission and 6.0L cooler.
2002 F-250 4X4 Extended Cab Short Bed, Swamps 175/146 single shot injectors, Hydra chip with Swamps tunes, RiffRaff FRx Fuel regulated system, 1.0 A/R Turbo Housing with high flow outlet, BTS Transmission with 6.0L cooler, 4" Exhaust, Tymar intake, RiffRaff boots and clamps, Wicked Wheel
jricherson is offline
post #3 of 3 (permalink) Old 05-06-2017, 10:59 PM
Originally Posted by stangman6796 View Post
Hello,
How long since your last oil change? What weight oil?
As your oil ages, it picks up soot, which causes it to get thicker.
The thicker oil takes longer to get flowing through the HPOP, which can cause long crank times.
My truck had been stored in my shop for an extended time, only being started every few months. It started taking longer to start, until I changed the conventional Rotella-T 15w40 for Rotella Synthetic 5w40. After the next start, crank time was back to normal. Even in the controlled environment, the oil had degraded.
It would've been interesting to send a sample off for testing, but I didn't think about it at the time.
David
2001 F-250 4x4 SC SB PSD 6-Speed, 3.73LS, Flo-Pro 4" Dual Exhaust, DP-Tuner F-5 , Gear Vendors OD, South Bend Con OFE Clutch, Peragon Folding Tonneau.
Cobranut is offline
