7.3 engine missing on #4 - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 01-10-2019, 08:29 PM Thread Starter
I have a 2002 f250 7.3 have a miss on cylinder 4 passes buzz test but not contribution test replaced injector same problem did compression test cold #2,355psi #4,350psi #6,350psi #8,355 on a 40 degree day at sea level I moved the new injector 4 to hole #2 and vice versa could bad uvch harness pass a buzz test but still not run correctly
Lastminute76 is offline
post #2 of 8 (permalink) Old 01-10-2019, 10:19 PM
klhansen's Avatar
My Photos: (180)
The buzz test only checks that the solenoid opens and closes the pintle valve in the injector. It could have plugged internal passages and not be getting any fuel.
Did the CCT failure move to #2 cylinder with the injector?
The buzz test will buzz all the injectors, but listening to the sound will help diagnose issues. A weak buzz might indicate a non-functional injector.
), AIS,
regulated return,
klhansen is offline
post #3 of 8 (permalink) Old 01-11-2019, 03:11 AM
Absolute's Avatar
To answer your question, yes the UVCH harness can pass the test broken. Most those breaks are intermittent and could be working during testing. Usually start failing when it warms up and wires expand. That's why they can be a Pita to trace. I too am curious if the failure moved with the injector to #2, or stayed on 4. If it stayed on , the harness is a good place to start. If the wires are brittle, there probably needing replacement. Good sign there wore out.
Absolute is offline
post #4 of 8 (permalink) Old 01-11-2019, 05:33 AM Thread Starter
No the cct failure did not move to #2 it still failed #4
post #5 of 8 (permalink) Old 01-11-2019, 05:45 AM Thread Starter
Truck has 218k miles on it
post #6 of 8 (permalink) Old 01-11-2019, 11:40 AM
Absolute's Avatar
Pointing to the harness, but what was the code for 4 when it failed? You could swap the harnesses from side to side to see if the failure follows the harness. That would at least tell you if its the harness. Bit of work , but a solid test.
Absolute is offline
post #7 of 8 (permalink) Old 01-11-2019, 12:14 PM Thread Starter
Truck had interment miss did contribute test came up with #4 failed cct and mis was getting worse so I replaced injector
post #8 of 8 (permalink) Old 01-11-2019, 02:40 PM
klhansen's Avatar
My Photos: (180)
Replacing UVCH's is good insurance whenever you have to open the valve covers. They cost a lot less than even 1 injector. ~$25-30 each if bought thru RockAuto. Same for glow plugs. How many times do you want to R&R the valve covers.
), AIS,
regulated return,
klhansen is offline
