7.3 long crank time - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 21 (permalink) Old 09-11-2014, 10:54 PM
So you check the reservoir level before this long crank session and level is within half inch or so from top?
If this is the case you will need a scanner capable of streaming live data to see what's going on.
Maryland dieselnick is offline
post #17 of 21 (permalink) Old 09-19-2014, 09:14 AM
I have the same problem with my 1999.5 F350. It started with longer crank times. Then check engine light comes on during start up and takes few minutes to go out. During this time engine idles little rough. Which is few seconds. The engine surges a second or two and check engine light goes out. Truck idles ok for that period of time of use. The truck will act this way every time i restart. This is in warmer temps. Sometimes it starts right up with no hesitation. Now with cooler morning temps of 50 degrees the truck starts on the first crank. No check engine light or rough ildes. But later in the day as it gets warmer it acts up again.
bluejoe is offline
post #18 of 21 (permalink) Old 09-19-2014, 11:41 AM
klhansen's Avatar
My Photos: (180)
Pulling the codes is always a good first start, but there are some quick checks you can do without a scan tool.
Pull the wiring connector off the ICP sensor (on the driver's side head right behind the alternator). If there's oil in the sensor it needs to be replaced. Try starting it and see if it starts and runs better. That's another sign that the ICP sensor is bad. The check engine light will stay on with the wires disconnected, but that's normal. If replacing the ICP sensor doesn't fix it you should get it scanned. You may have an issue with the IPR (Injection Pressure Regulator).
), AIS,
regulated return,
klhansen is offline
post #19 of 21 (permalink) Old 09-19-2014, 01:26 PM
Googs's Avatar
Try what Kl has said first if it persists and you have a chip in remove it and try to start, see what happens then.
If all that fails get to a scanner that's capable of reading powerstrokes .
03 F250 4x4 CC 7.3ltr 4R100HD rebuilt, 160,000 Klms
GTP38R , Turbo-master , IH Bellowed up pipes, RiffRaff CAC boot kit, AIH delete, .
4" Turbo back exhaust ,Banks power elbow, LPG (Gas over diesel) DP F6 tuner, 40hp tow, 60hp tow, 80hp tow, 60hp, 80hp, 120hp race, Decel, 1200 RPM.
RiffRaff 6637 intake ,pre filter, Snorkle
Custom made trans cooler with twin thermo fans ,water to oil cooler
Scangauge 11,AutoMeter Trans temp, pyro ,Water/Oil temp, Fuel Pressure, Boost.
Longrange 120 ltr fuel tank and transfer pump, 15,000 lb winch, Warn winch bar, Lightforce HID spot lights, HID headlights, Black Widow Drawer System, Snugtop Canopy with gull windows, Fr & Rr ARB Diff locks, Hornblaster Train horns, Post fuel pump filter, RiffRaff FRx and HPx , Bilsteins x4, Onboard compressor , Air tank and water traps, Billet door handles, Alpine headset, Alpine overhead DVD player, Rockford Fosgate sub, Alpine amp and CD changer.
Googs is offline
post #20 of 21 (permalink) Old 04-28-2019, 01:19 PM
Hey everyone I have a 2002 f350 7.3. I had the problem where I had to plug in my truck 1hr before starting it in the summer to get it rolling. Everyone told me it could be your glow plugs or the injectors, high pressure oil pump. I was ready to scrap it because I couldn't afford to spend that kind of money. I did some research replacing the glow plug relay, the previous owner had 15-40 oil so I put in 5-40 synthetic in. And paid 70 bucks for a cam position sensor 10min fix started right away and purred like a kitten. No more rough idle and that sound of poor fuel distribution.
Whitezombie is offline
post #21 of 21 (permalink) Old 04-29-2019, 08:50 PM
ArcticDriver's Avatar
@Whitezombie,
Yes the Glow Plug Relay (GPR) has a high failure rate like you experienced.
If it happens to you again then you might want to do what many of us have done and replace with a “larger” Stancor (White-Rogers) GPR.
You can buy one at Diesel O-rings:
http://www.dieselorings.com/16-009-w...lug-relay.html
If your 7.3 would start after being plugged in then your CPS was probably still “good” so you might want to keep it as a spare in your glove box with a 10-mm wrench.
SOLD:
ArcticDriver is offline
