7.3 white smoke - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-18-2019, 08:47 PM Thread Starter
jesse7869's Avatar
7.3 white smoke
2000 f-250 7.3 white smoke from exhaust at random times as the truck gets hotter over time of driving it the injectors get louder 280,000mi no blow by just a little white vapor any help would be appreciated
jesse7869 is offline
post #2 of 8 (permalink) Old 03-18-2019, 09:42 PM
ArcticDriver's Avatar
A few more details might help get you some responses.
280K is high for original injectors, have they been replaced?
Are you sure its random?
Not when you accelerate?
Not when it changes gears?
Auto Trans?
It does not happen when cold?
Do you have a tuner or stock?
Any SES (Check Engine Light) illuminated on dash?
White probably means unburned fuel.
Is your coolant level stable in your degas reservoir?
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is online now
post #3 of 8 (permalink) Old 03-19-2019, 06:07 AM Thread Starter
jesse7869's Avatar
coolant hasn’t gone down down since i owned it it’s just a little puff the only time i can notice it is at night when someone’s headlights shine in my exhaust and yes i believe so original injectors i bought it from the first original owner with 270,000 on it ran an injector buzz test and they all sound pretty much the same but could it be a leaking injector? or could it be low fuel pressure?
post #4 of 8 (permalink) Old 03-19-2019, 07:19 AM
Whiskyb's Avatar
Mine puffed white smoke on deceleration, turned out to be bad turbo
Whiskyb
2001 F350 4X4 Super Duty PSD Dually
Almost 400k and still given her
DP Tuner
and guages, DIY air intake, BTM,
Dieselsites trans and coolant filters
Wicked wheel 2 (Gone) , Guzzles billet fpr
Whiskyb is offline
post #5 of 8 (permalink) Old 03-19-2019, 07:24 AM Thread Starter
jesse7869's Avatar
it happens mostly when i’m sitting at a light and at acceleration but clears up once higher rpms but like i said it’s very very small amount and i can only see it at night when cars headlights shine near my exhaust
post #6 of 8 (permalink) Old 03-19-2019, 03:24 PM
klhansen's Avatar
My Photos: (180)
Could be leakage at the turbo seal. Oil could build up in the turbo at idle then get blown out when you take off. Remove the intake hose to the turbo and check the shaft for end play. There shouldn't be any, but if you move it side to side, you may feel just a touch of play. That's not a cause for concern.
Also a buzz test won't find an injector nozzle that's drooling fuel.
), AIS,
regulated return,
klhansen is offline
post #7 of 8 (permalink) Old 03-19-2019, 10:23 PM Thread Starter
jesse7869's Avatar
no shaft play put the wicked wheel in about 2 months ago and it has been doing it since i got it but i also have a rich diesel smell from the exhaust but i have a hydra chip could that be from the chip? or leaking injectors? or both?
post #8 of 8 (permalink) Old 03-22-2019, 07:13 PM
Absolute's Avatar
You need gauges. Sounds like the Hydra is giving you fuel, and the turbo isn't responding in time. So possible boost leak. Since it clears in the higher rpm, boost leak seems likely. That said, I get a puff of black with my performance tunes too. Higher the power gain, bigger the cloud. A good tuner can get past that, but it requires live tuning. A generic chip is going to smoke on the launch.
Absolute is offline
Similar Threads
99 7.3 white smoke loss power rough running luke213 '99 & up 7.3L Power Stroke Engine and Drivetrain 0 10-07-2014 07:16 PM
All of a sudden - White smoke at all RPMs. maplemale '99 & up 7.3L Power Stroke Engine and Drivetrain 32 06-27-2014 07:11 PM
white smoke surprise patshea098 '99 & up 7.3L Power Stroke Engine and Drivetrain 8 07-01-2011 06:56 PM
White Smoke from 2003 7.3 - Could it be loose manifold pipe? gillilandlandscape '99 & up 7.3L Power Stroke Engine and Drivetrain 1 08-09-2010 09:46 PM
6.9 and 7.3 parts interchangeable? RajinCajun 7.3L IDI Diesels (Not Power Strokes) 15 03-26-2006 11:46 PM
