The 7.3L PSD "Cackle" - Page 4 - Diesel Forum - TheDieselStop.com
 9Likes
post #46 of 50 (permalink) Old 02-17-2017, 11:48 PM
yan7gin's Avatar
Just received the 4 line kit today and let me tell you that it is not easy to install. To make the job a bit easier, the entire top of the engine had to be strip, a/c compressor and alternator as to be move also as both bracket. Turbo may be removed for easier access but up pipe as to be removed/lose to get the fitting install.
The kit is well made and fit really good.
Truck should be running by end of the weekend so will let you know how it performs
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #47 of 50 (permalink) Old 02-25-2017, 04:51 PM
yan7gin's Avatar
@ArcticDriver other than the installation that was PITA, the 4 line kit does reduce injectors noise when the engine is cold and warm. Overall i really like it and would do it again
ArcticDriver likes this.
F350 2002 7.3
yan7gin is offline
post #48 of 50 (permalink) Old 02-25-2017, 07:19 PM Thread Starter
ArcticDriver's Avatar
Congrats on getting your truxk running again !
SOLD:
ArcticDriver is online now
post #49 of 50 (permalink) Old 02-25-2017, 10:38 PM
yan7gin's Avatar
ya thanks, it was about time 3 weeks without driving it was way too much. truck feel amazing now
Phil G. likes this.
F350 2002 7.3
yan7gin is offline
post #50 of 50 (permalink) Old 03-04-2017, 10:46 PM
Artic Driver
Did you find your erratic idle problem ?
2000 f250 crew cab,100,000 miles, 3:73 gear
1997 F250 7.3, 4:10 gear
The 97 feels like it pulls better then the 2000
lbvb is offline
