7.3L stubles while driving - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-03-2018, 08:21 PM Thread Starter
B1000's Avatar
My truck has had this stumble while low speed cruising to work. My commute is short, only 2 miles. But I have noticed the truck seems to have this stumble. You can feel it but I am not seeing it in the tach. Been around for 3 tanks of fuel does it when warm and cool.
Oil, filter and fuel filter all changed. Didn't change.
01 F-250 Lariat ECLB 4x4 PSD
01 Excursion limited 4x4 7.3 PSD Upgraded 4R100, Edge Attitude CTS w/ juice. Airaid CAi. MBRP 4" turbo back.
Gone but not forgotten
02 F-350 Lariat 7.3 PSD 4x4 CCLB Straight piped. and 370ksmiles has rolled its last coal
94 F-250 7.3 IDI NA, 5spd, 4x4,Reg cab, long bed. Dyno Max Exhaust, 285 BFG AT on 16x8 aluminum Ultras, 7.5ft Blizzard snow plow 310K miles SOLD
B1000 is offline
post #2 of 7 (permalink) Old 12-03-2018, 11:57 PM
ArcticDriver's Avatar
2 miles?
Time to ride a bike.
SOLD:
ArcticDriver is offline
post #3 of 7 (permalink) Old 12-04-2018, 06:54 PM
Try driving a longer distance to see if that helps.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #4 of 7 (permalink) Old 12-05-2018, 03:16 PM Thread Starter
B1000's Avatar
It does have the stumble on longer drives after warming up. It seems to ussually happen around 30-35mph. Just cruising, if I hammer down on it it's fine but once I start cruising along at around 30-35mph the stumble comes back.
B1000 is offline
post #5 of 7 (permalink) Old 12-05-2018, 05:02 PM
Does it feel like it could be a dead spot in your accelerator pedal travel?
And its engine related rather than the transmission shifting into a new gear? Assuming A/T.
SOLD:
post #6 of 7 (permalink) Old 12-07-2018, 07:55 AM Thread Starter
B1000's Avatar
It doesn't feel like it's happening during a shift or that the trans is searching. I'll look into the dead pedal spot.
All my 7.3s have been so reliable I never work on them other than oil and fuel filters diagnosis is difficult.
B1000 is offline
post #7 of 7 (permalink) Old 12-07-2018, 09:49 PM
They are great trucks!
SOLD:
