'99 F350 underhood fuse 25 - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 02-07-2015, 07:32 PM Thread Starter
Question '99 F350 underhood fuse 25
I am loosing power to my fuse 25 underhood and the truck dies when it drops out. The truck starts and runs great just as soon as the power comes back. I have not been able to locate a wiring diagram that shows where the fuse gets its power from.
99 f350 bonestock 400000 strong
tobypower is offline
post #2 of 10 (permalink) Old 02-07-2015, 11:06 PM
Give me the circuit and I can shoot you a picture of a 2000 diagram. There can be differances from one year to the next but it might be 100 percent accurate or just part of it.
Let me know, I'll check in tomorrow. It's way too late for schematics.
Maryland dieselnick is offline
post #3 of 10 (permalink) Old 02-08-2015, 06:50 AM Thread Starter
sorry wrong number its 24 but its labled as power distribution box
post #4 of 10 (permalink) Old 02-08-2015, 03:21 PM
Ok, what is in the circuit or what number is it? What does it feed.
The circuits in the book are broken down in components and circuit types.
post #5 of 10 (permalink) Old 02-08-2015, 03:35 PM
Does this look right? Fuse for the pcm relay?
A lot of times that fuse blows from the fueł bowl heater shorting out. Unplug it's connector, replace the 20 amp fuse and see if you are good.
You can get a new updated heater element from Diesel Orings.com
post #6 of 10 (permalink) Old 02-08-2015, 05:14 PM
klhansen's Avatar
My Photos: (180)
Nick could be on to it, but the fuse that powers the fuel heater is on the coil side of the PCM power relay. It's #30 (30A) under the dash. I've had that issue (see this thread: http://www.thedieselstop.com/forums/...-fixed-239318/)
If it's Fuse 24 in the Battery junction box, it's more likely a short in a wire that's on the contact side of the PCM power relay. That relay feeds the following items:
PCM
Transmission
Fuel Pump (via the fuel pump relay)
Brake Pressure Switch
Injection Pressure Regulator
Glow Plug Relay
Intake Air Heater Relay
The last three are on the engine, so susceptible to vibration causing chafing and shorting.
Check your engine harness to see if there are any spots shorting against the engine.
), AIS,
regulated return,
klhansen is offline
post #7 of 10 (permalink) Old 02-08-2015, 05:28 PM
Thnx Kevin, I had the 24 fuse in junction box for the pcm relay and was mistaken about the heater being on that side rather the heater being on pcm fuse in fuse box. My bad
That is the battery junction box.
post #8 of 10 (permalink) Old 02-08-2015, 06:55 PM Thread Starter
thanks for the info im suspect its going to be in the engine harness the problem started when the engine was swapped and has kept getting worse
post #9 of 10 (permalink) Old 02-19-2015, 07:37 PM Thread Starter
I wanted to let everyone know what I found so maybe it will help
I checked my wiring harness twice end to end repaired multiple bare spots to still have truck dieing and not starting back for anywhere from 2 min to 20 .
I finally pulled PCM to check connections and found a superchip plugged in.
I removed chip truck ran perfect (little less power now) but doesn't shut down.
post #10 of 10 (permalink) Old 02-19-2015, 08:23 PM
klhansen's Avatar
My Photos: (180)
Glad you found out what was going on. Sound like that chip had a heat issue. Checking for a chip and removing it should always be the first step in troubleshooting.
), AIS,
regulated return,
klhansen is offline
