LinkBack | Thread Tools | Display Modes |
Alternator/melted wire question, 2002 F250
My 2002 7.3 quit charging and I verified that there was no charge going to the batteries. Had a look today and on the passenger side battery, there was a melted set of wires attached the side positive post. Do these route back to the alternator? Or part of the fuse system? Or did my alternator start putting out to much voltage and melted the wires? I uploaded photos but I'm not sure how to get them to view on the thread.
2010 Ford F250 CC Lariat 4x4, Spartanized
Sponsored Links | |||
Advertisement |
New update, pulled the alternator, had it checked and it grounded itself. Therefore it fried what I assume were the fusable twin wires right at the passenger battery post. Ford spent 15 min and could not find the part and all they wanted to do was replace the harness. Napa drew a quick blank. Does anyone know the part # or gauge of fuse? Can it be replaced? In Canada, so does anyone know where to get one? Can I install myself, because I didn't think it could be soldered, only crimped.
You probably have an 8 gauge battery wire and a 12 gauge fuse link. If you can't find any fuse wire you could use a maxi fuse.
Advertisement |
My Photos: (180)
Originally Posted by dgiles
View Post
Fusible links are short lengths of wire that are smaller in diameter than the wires they are protecting. Fusible link wire is covered with a special thick, non-flammable insulation. An overload condition causes the insulation to blister. If the overload condition continues, the wire link will melt. To check a fusible link, look for blistered insulation. If the insulation is okay, pull lightly on the wire; if the fusible link stretches, the wire has melted.
When replacing fusible links, first cut the protected wire where it is connected to the fusible link. Then, tightly crimp or solder the new link to the protected wire.
Fusible links are often identified by color coding of the insulation, as shown here:
Code:
Wire Link Size Insulation Color 20 GA Blue 18 GA Brown or Red 16 GA Black or Orange 14 GA Green 12 GA Gray
This is from a 99 service manual, but I'd be surprised if other years had smaller fuseible links.
You should be able to get fusible link wire at about any auto parts store, although I've never tried. Not surprised that your Ford place couldn't find them. They probably get them in a kit with an assortment of sizes/colors, and the guy was probably looking for a part #.
), AIS,
regulated return,
Yep your right. It is grey and the wire has melted. Found some fusable links at the auto parts store. You would have thought that considering an alternator usually goes at some time or more in a trucks life, and a large percentage will short, causing the fusable link go, they would have come up with a better way to replace that link.
View Post
The fusable link is a cheaper alternative to a circuit breaker or high-amp fuse. And, it takes more careful repair to replace than either of the other two methods which forces shadetree mechanics to search for the short rather than just resetting the breaker or replacing a fuse.
Current truck: 2002 PSD 4x4, CC, XLT, F350 dually, 4.10 gears. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO gauges (boost, EGT, trans, fuel pressure), PHP Hydra, full EBPV delete (pedestal & outlet), CNC Fab HP & HPX lines, Riff Raff FRX, Riff Raff IC boots, CCV mod w/catchcan, Reese Titan, AIS, ITP pre-pump filter kit, in-tank mods, Redhead steering box, Riff Raff billet compressor wheel, Ultra-Power bellows up-pipes, 6.7L starter.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, CCV mod, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, ITP pre-pump filter kit.
View Post
just did a search on this, thanks for the info . Batteries were not charging batt light was on , fusible link melted, thinking of putting in a 50 amp max fuse, because I can't find the amp rating of the link , and I'd rather replace a fuse than the wire.
early 99 f350 cc dually 6 speed K&N cone filter, delete airbox, edge 3 stage, good cupholder ,warn hubs,90k
Originally Posted by e94racer
View Post
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
______________________________________________
The first part to be thrown at these trucks should be a PSD compatible scanner
PM please. No Visitor Msg if you want a response anytime soon
My Photos: (180)
Agree totally with tinman.
Considering that your alternator is rated for 110 Amps, even two 50A fuses in parallel would probably fry pretty soon.
), AIS,
regulated return,
e94Racer
So what fuse size amp worked? I have the same issue and can't find any solid answers.
Thank you
Thank you
My Photos: (180)
Originally Posted by Masgrosero
View Post
e94Racer
Thank you
Thank you
), AIS,
regulated return,
Advertisement |
No Start. Looking for ideas
Currently Active Users Viewing This Thread: 7 (5 members and 2 guests) | |
444-4D, bugman, DENNY, Tparker |
Thread Tools | |
Display Modes | |
Posting Rules | |
