Alternator replacement plan? - Page 2 - Diesel Forum - TheDieselStop.com
 2Likes
post #16 of 20 (permalink) Old 03-01-2019, 02:59 PM
ArcticDriver's Avatar
Do any of you keep an eye on your voltage using a ScanGuage-2 ?
It gives me a heads up to My charging system.
What are your most common types of failures? Voltage Regulator? Etc?
SOLD:
ArcticDriver is offline
post #17 of 20 (permalink) Old 03-01-2019, 07:40 PM
RT
RT's Avatar
Originally Posted by Stroking it View Post
Not sure why anyone would carry spare alternators or starters in there trucks. These parts rarely fail.
Because Murphy’s law says a part that you have on hand will never fail on side of the road in the middle of nowhere. Thats why I keep extra hoses and belts, a CPS, IPR valve and ICP sensor in the truck.
RT is offline
post #18 of 20 (permalink) Old 03-01-2019, 09:10 PM
bugman's Avatar
My Photos: (12)
I once asked on this forum what spare parts I should carry as a just in case something happened.
The only thing that they all forgot was the trailer to carry all the parts in.
bugman is offline
post #19 of 20 (permalink) Old 03-02-2019, 09:41 AM
69mach1377's Avatar
Who makes the OEM ones? They last pretty long...
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #20 of 20 (permalink) Old 03-02-2019, 02:34 PM
TYC is an OE manufacturer. It is available from rock auto with a lifetime warranty. But the OP said that he didn't want to order one by mail because it would be more convenient to just take it in to his local parts store for replacement when it fails.
69mach1377 likes this.
DonWarkentin is offline
Similar Threads
Survey: maintenance costs vs Ford maintenance plan costs Brown Dog 6.4L Power Stroke Engine and Drivetrain 15 12-16-2014 11:28 PM
X plan discount DieselinMiami '11-16 Ordering Information 9 08-13-2010 11:23 AM
Premium Maintenance Plan RustySocket 6.4L Power Stroke Engine and Drivetrain 4 08-08-2009 12:32 AM
How many of you have a Ford ESP plan? tly 6.0L Power Stroke Engine and Drivetrain 4 03-12-2009 12:46 PM
Additional Ford Employee A/X Plan PINS WillSD 1999-2007 Ordering Information 4 10-20-2004 03:08 PM
