If a filter can stop crud from getting back into the transmission, why wouldn't it prevent crud from getting into the cooler also?
It could, but if there's already crud in the cooler, the idea is to keep it from getting back to the tranny. If your tranny and cooler are new, it definitely wouldn't hurt to add a filter either before or after the cooler.
), AIS,
regulated return,
