Changed the fuel filter ran good then died - Page 2 - Diesel Forum - TheDieselStop.com
 3Likes
post #16 of 30 (permalink) Old 08-14-2018, 01:13 AM
jleedog's Avatar
Originally Posted by Dhoop49 View Post
We noticed the old filter had some loose glue is it possible that some of this material got into a valve or the check valve and stopped fuel to the pump? We have fuel to the bowl but not out of it
Yes its very possible, you should take the standpipe out and inspect it. I comes out easily and comes apart easily. I don't even have the plunger in mine anymore, I removed it entirely.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #17 of 30 (permalink) Old 08-14-2018, 08:26 PM Thread Starter
Checked both fuses checked the icp removed and inspected the stand pipe and Valve. Even removed the plunger and still no fire. Any other ideas on which way to go from here ? Thanks for the help so far
Dhoop49 is offline
post #18 of 30 (permalink) Old 08-14-2018, 08:29 PM Thread Starter
Couldnit be the cam sensor ? Where is it located if it may be
Dhoop49 is offline
post #19 of 30 (permalink) Old 08-14-2018, 08:44 PM
jleedog's Avatar
This may help. Might not be the same year as yours, but its the same location. CPS would have been one of the #1 things to check. You should carry a spare in your truck, they are prone to failure eventually. Replace only with OEM Motocraft part. Aftermarket ones have a proven to be problematic and not worth the money saved.
jleedog is offline
post #20 of 30 (permalink) Old 08-14-2018, 08:51 PM
jleedog's Avatar
One more possibility is the IPR valve located under the HPOP. It controls the amount of fuel to the injectors. It has a small tin nut on the end of it that can come loose ( Look for it in the valley of the engine).and fall off resulting in no start issue.
jleedog is offline
post #21 of 30 (permalink) Old 08-14-2018, 09:21 PM Thread Starter
We've noticed the ipr is oil soaked. So this maybe our problem? Will an ipr just shut the truck down ?
Dhoop49 is offline
post #22 of 30 (permalink) Old 08-14-2018, 09:23 PM Thread Starter
Can we clean off the coil Will that be possible? Or do we need a new one?
Dhoop49 is offline
post #23 of 30 (permalink) Old 08-14-2018, 10:15 PM
jleedog's Avatar
A bad IPR will cause a no start issue.I don't think cleaning the coil will help but you can try., you obviously have an oring that has gone bad. that's why it is oily. Oil soaked wires can cause problems with electrical components. If you could read IPR values via a reader it would help diagnose the problem. Invest in a Scangauge II or a similar devices that will read many of the parameters that these trucks require to run. A new Motocraft IPR will set you back about 160$
jleedog is offline
post #24 of 30 (permalink) Old 08-16-2018, 03:23 PM Thread Starter
Update... So far everything we've done has had no effect. Guess we're going to try changing the IPR.
Dhoop49 is offline
post #25 of 30 (permalink) Old 08-16-2018, 05:53 PM Thread Starter
Pulled the drain plug out of the hpop and no oil however the res is full
Dhoop49 is offline
post #26 of 30 (permalink) Old 08-16-2018, 05:54 PM Thread Starter
Do we have a bad pump?
Dhoop49 is offline
post #27 of 30 (permalink) Old 08-16-2018, 06:23 PM
jleedog's Avatar
Saw a youtube video from Dieseltechron that shows how to deadhead a pump with some fittings and an ICP sensor to see if its working properly. But that would require you having a way to read data which would probably help you to fix the problem.
jleedog is offline
post #28 of 30 (permalink) Old 08-16-2018, 11:37 PM
ArcticDriver's Avatar
Here is a good description of the HPOP system including the role of ICP & IPR.
https://deadheaddiesel.com/7.3-powerstroke-hpop/
jleedog likes this.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #29 of 30 (permalink) Old 08-18-2018, 12:10 PM
Are you using a motorcraft filter and separated cap? I have seen aftermarket cap and filter combos that will not screw down far enough to push down the valve in the fuel stem. It could be just barely pushing it down.
2000 F350 DRW 7.3
tomlin is offline
post #30 of 30 (permalink) Old 08-23-2018, 11:18 AM Thread Starter
Update. Replaced the IPR when we did we noticed no oil in the pump but the res is full. I'm thinking this is our problem. How is the pump fed from the res? Can this be plugged?
Dhoop49 is offline
