Continuity between glow plug line and ground? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By RT
post #1 of 13 (permalink) Old 05-30-2018, 09:42 PM Thread Starter
i'm trying to diagnose some electrical issues (after replacing dead batteries, now the whole electrical system is dead)
one thing i noticed is i have continuity between the line from the GPR and ground, i would think maybe some but there should be some high resistance because of the glow plugs right?
upjeeper is offline
post #2 of 13 (permalink) Old 05-31-2018, 07:51 AM
RT
RT's Avatar
Are you measuring the battery side of the GPR or the glow plug side? If it's the glow plug side, then you should see resistance. That's because the glow plugs are resistive heaters. Are you getting any activity after the battery swap? Will the headlights turn on?
RT is offline
post #3 of 13 (permalink) Old 05-31-2018, 07:59 AM Thread Starter
continuity from the glow plug side to ground
after putting in new batteries everything died. no crank, no lights, nothing
upjeeper is offline
post #4 of 13 (permalink) Old 05-31-2018, 10:12 AM
RT
RT's Avatar
If you have no lights, you’ve got a battery connection issue. That circuit doesn’t go through the computer or ignition.
RT is offline
post #5 of 13 (permalink) Old 05-31-2018, 10:34 AM Thread Starter
yes sir, thank you. i would agree
my concern now, is how much resistance should i see between the ring terminals (on the glow plug side) and the ground? i'm concerned there could be something wrong on the glow plug side.
upjeeper is offline
post #6 of 13 (permalink) Old 05-31-2018, 11:12 AM
RT
RT's Avatar
Since the glow plugs are wired in series (not parallel), the resistance would be cumulative. The normal glow plug resistance range is 0.6-2.0 ohms. You have 8 glow plugs. Assuming they are all working, you should have between 4.8 and 16.0 ohms.
RT is offline
post #7 of 13 (permalink) Old 05-31-2018, 11:42 AM
bugman's Avatar
My Photos: (12)
Actually the glow plugs are wired in parallel. Series would be connecting one glow plug + side to the next glow plugs - side and the rest the same way.
Parallel is wiring the + side of all the glow plugs together with their - sides being the ground.
But I don't believe that the problem is the glow plugs but something else unless the OP changed out the relay to a case grounded relay which would put the glow plugs on 100% of the time that the key is on.
bugman is offline
post #8 of 13 (permalink) Old 05-31-2018, 12:00 PM
bugman's Avatar
My Photos: (12)
To clarify it a little bit more to find the resistance of a series circuit you would add the resistance of glow plug 1+ glow plug 2+ glow plug 3 and so on.
To find the total resistance for a parallel circuit is a little bit more complicated.
bugman is offline
post #9 of 13 (permalink) Old 05-31-2018, 01:26 PM
RT
RT's Avatar
1/(1/R1+1/R2=etc) - that would lend a value of 0.075 to 0.25.
Must have been half asleep earlier...
bugman likes this.
RT is offline
post #10 of 13 (permalink) Old 05-31-2018, 09:43 PM
tinman13kup's Avatar
You been out in the sun too long?
As for the no power thing, don't forget the fuse links, but if those are opened, I would be checking to see why.
Was there ANY life when you installed the batteries, or did nothing work right from the get-go?
Tom
99.5 PS CC 4x4 SRW ZF-6
- AKA "The Big White Truck"
______________________________________________
The first part to be thrown at these trucks should be a PSD compatible scanner
PM please. No Visitor Msg if you want a response anytime soon
tinman13kup is offline
post #11 of 13 (permalink) Old 06-02-2018, 07:29 PM Thread Starter
i figured out why i had no electrical, the connection on the driver side fender rusted through. i have replaced it this morning and i've got power again
but still cannot get torque pro to communicate with my ECU. i can hear my fuel pump, and most lights (ABS, glow plug, etc, and etc) are lit up on my dash in the key on / engine off position. something is not right.
upjeeper is offline
post #12 of 13 (permalink) Old 06-02-2018, 08:12 PM
RT
RT's Avatar
Check the cigarette lighter fuse.
RT is offline
post #13 of 13 (permalink) Old 06-03-2018, 02:09 PM Thread Starter
thank you sir. i've checked that, fuse is good. i also checked any fuse that appears it could be remotely related.
plus i've systemically disconnected the Intake Air Heater, Fuel Bowl heater, and the Exhaust Back Pressure Valve and after each was disconnected i checked again.
it seems when i go from key off, to key on after it sits for a couple of minutes it appears i can connect to the ECU long enough to scan for fault codes (first thing i do every time) but when i go back into Torque Pro for monitoring it looses connection. I'm not sure if it's just timing or if it's actually something to do with the connection.
I'm going to start testing relays next. any other ideas please?...
upjeeper is offline
