Cranks smokes but no start - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-07-2019, 08:58 PM Thread Starter
73IDI's Avatar
My dad just got a 03 F350 166xxx miles 100% stock and is having cold start issues and can't really find any answers in a search so I'm asking. The truck will crank over fast and even sound like a cylinder or more is trying to hit and gets smoke out of tail pipe but will not start if you dont plug it in which led me down the glow plug path but the glow plugs all ohm to around .7, glow plug relay is new and working and new batteries, new fuel filter even took valve covers off and ran continuity check on all the glow plug wires. I also tried unplugging the icp and cranking with no luck because that seemed to be a common thing to try in my searches. Also could be unrelated I dont know but it has no power until it gets up to temperature. What am I missing I got cranking speed air and fuel but wouldn't start with out plugging in.
1973 F250 4x4 with 7.3IDI swap. NP435 4sp trans. Banks turbo
2006 VW Jetta TDI daily driver
2003 F350 4x4 6sp cab and chassis with flat bed
Sold: 1996 F350 powerstroke
2006 2500 GMC duramax
2001 F350 powerstroke
73IDI is offline
post #2 of 6 (permalink) Old 04-09-2019, 10:21 PM Thread Starter
73IDI's Avatar
To clarify the smoke is like grey fuel smelling like it's getting fuel but not firing off
UPDATE: Changed IPR and oil temp sensor and made no difference but if you unplug the oil temp sensor it will start after several tries with a very low rpm idle that is very rough and smoothes out the longer it runs and warms up I'm at a loss here seems like its engine temp related or even a timing issue until it warms up
73IDI is offline
post #3 of 6 (permalink) Old 04-11-2019, 11:22 AM
Absolute's Avatar
First off, a 2003 is a DI, not an IDI. IDI is the motor before the powerstroke. What you describe is the classic bad starter. Yes it appears to spin fast, faster than a gasser. BUt as most find, if its not 150rpm or more, it will not start. In your case, of course the glow plugs help , as a warm engine starts easier. The fact you sense a cylinder or two trying to fire, shows its not spinning fast enough. Go to the parts store and buck up for a denso starter. Its huge, barely fits, some like me even had to take a quarter inch off the cross member to fit it in there. Well worth the money. You will immediately see the spin speed difference. OR just get a stock one. Try it before you return your core. Bet it fixes the issue. If not return it , no harm done. But your description totally points to a slow starter. Also, DO NOT FALL FOR THE PARTS STORE, BRING IT IN AND WE CAN TEST IT. They cannot test starters. They are lying. All they do is put power to it, if it spins an pops out, they call it good. Fact is, it has to have a full load on it to test it. They cannot do that. So just buy a new one and try it. Should fix ya up. Your mileage is right on the common need a new starter mileage as well. Im on my 4th, now have the denso, probably wont need another.
Absolute is offline
post #4 of 6 (permalink) Old 04-13-2019, 09:12 AM
Absolute's Avatar
Guess the starter must have fixed him up since he didn't reply back. lol
Absolute is offline
post #5 of 6 (permalink) Old 04-16-2019, 05:37 AM Thread Starter
73IDI's Avatar
No I didn't reply because you sort of implied I was stupid and I figured I'd just wait till I actually had an update on the issue.
"First off" I KNOW it's not an idi obviously I posted in the 99 and up powerstroke section and I mentioned the icp which I also know an idi doesn't have. I dont know everything there is to know and I appreciate the reply but it just kinda struck me wrong. Maybe I miss interpreted.
Now that I got that off my chest. I have since taken the truck to a mechanic with the proper diagnostic tool and he said the icp is bad and the computer wasn't showing and dada from it. He recommended changing it so he can run another test something that has to do with high pressure oil.
73IDI is offline
post #6 of 6 (permalink) Old 04-16-2019, 06:28 AM
Absolute's Avatar
That's too bad, no one was trying to make you feel stupid. I'll let the others handle this from here since we got off wrong. BUT, you do not need a new computer, theres nothing wrong with yours. Your mechanic is pulling at straws. CPU is expensive , and definitely not your issue. Good luck.
Absolute is offline
Similar Threads
'2007 F250 6.0L Starts Then Stall, now cranks with no start 6.0Eh 6.0L Power Stroke Engine and Drivetrain 12 11-24-2018 09:30 AM
All of a sudden, '2005 6.0L Cranks but won't Start :( cowdoc 6.0L Power Stroke Engine and Drivetrain 19 05-10-2018 10:44 AM
Low Oil Cranks No Start NorCalStroker01 '99 & up 7.3L Power Stroke Engine and Drivetrain 7 05-03-2018 10:14 PM
Help! Engine Cranks. No Start. Fuel. Compression. ICP? IPR? Sensors? roadwarriors360 '99 & up 7.3L Power Stroke Engine and Drivetrain 1 06-14-2017 12:16 AM
