Dead in Wyoming - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 26 (permalink) Old 08-08-2018, 07:24 PM Thread Starter
REOutdoors's Avatar
My 03 was having trouble starting yesterday. Set tunes back to stock and it started. Driving back to Colorado today it died. Fuel cup is not holding fuel but pump seems to be working. Any trouble shooting will be great. I’m headed back Friday morning with my 02 and a trailer to tow her home. Truck has 144k on it
REOutdoors is offline
post #2 of 26 (permalink) Old 08-08-2018, 09:01 PM
losfinch's Avatar
What do you mean that the fuel cup isn't holding fuel? Is it leaking out? How do you know that it isn't holding fuel? Not too many places that it can go you know
Also, as far as it having trouble starting I assume that you mean that it was turning over but refusing to fire?
What kind of tuner do you have on it?
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #3 of 26 (permalink) Old 08-10-2018, 06:34 PM Thread Starter
REOutdoors's Avatar
So my buddy was using my rig. I am headed out in the wee hours of the morning with my other truck and trailer to get it. I’m running the edge evolution in towing mode:
To my knowledge here is what occurred:
It was running fine but every once in a huge while it would lunge and the check engine line would pop on. As soon as you shut the truck off and restart it the light would disappear.
My buddy said it started great the night befor and when he got into it in the morning it would turn over but wouldn’t start. I walked him through setting the computer back to stock settings he did so and it fired right up. He pulled out of Jackson hole Wednesday and made just outside Rawlins when he said it just lost power and wouldn’t start. He had it towed into Rawlins where I will be picking it up in the morning.
Any common sensors that it could be? The evolution has the diagnostic on it so I will run that when I get there. It’s hard to diagnose over the phone when your buddy is not a diesel guy at all.
post #4 of 26 (permalink) Old 08-10-2018, 07:27 PM
RT
RT's Avatar
One possible issue could be the IPR valve. The solenoid can get weak and then fail when hot. Usually, it will start up fine after it cools down and then repeats the cycle once it warms up. Fuel pressure would be another thing to check.
jleedog likes this.
RT is offline
post #5 of 26 (permalink) Old 08-10-2018, 09:19 PM Thread Starter
REOutdoors's Avatar
I’ll check it out. Appreciate the help. If the fuel pressure is weak what would be the exit thing to check?
post #6 of 26 (permalink) Old 08-10-2018, 10:14 PM
RT
RT's Avatar
Make sure the pump is running. Confirm you have more than 1/4 tank of fuel. Check the filter. Possibly the regulator is stuck open.
RT is offline
post #7 of 26 (permalink) Old 08-10-2018, 10:21 PM Thread Starter
REOutdoors's Avatar
Roger that. Would a ipr create the weird jolt like the truck looses all power but comes right back if it’s failing but not completely bad?
post #8 of 26 (permalink) Old 08-10-2018, 10:22 PM
79jasper's Avatar
I would look at icp and cps.
Sent from my SAMSUNG-SM-G920A using Tapatalk
79jasper is offline
post #9 of 26 (permalink) Old 08-10-2018, 10:53 PM Thread Starter
REOutdoors's Avatar
I will look at those as well. Hopefully it’s just a sensor and I can do a quick roadside repair and get er back on the road!
post #10 of 26 (permalink) Old 08-11-2018, 07:59 PM Thread Starter
REOutdoors's Avatar
I ended up having to tow the sucker home. It’s been a long day. There was no oil in the Hpop res and the computer is not allowing any scanners to read. Not even my edge evolution cts2.
post #11 of 26 (permalink) Old 08-11-2018, 08:40 PM
ArcticDriver's Avatar
Did you know you are not able to receive PMs?
How is your oil level?
The HPOP could have been emptied while trying to start the engine multiple times.
You could try adding oil to the HPOP and see if it drains out (possible bad oil seal)?
You should top up the HPOP before trying to start it again.
But the initial cause of the no-start may still be something else.
SOLD:
ArcticDriver is online now
post #12 of 26 (permalink) Old 08-11-2018, 09:56 PM Thread Starter
REOutdoors's Avatar
Why won’t the scanners connect to the pcm?! Should I not be concerned about that? I also changed the cps. I’m pretty certain it’s the original.
post #13 of 26 (permalink) Old 08-11-2018, 10:05 PM
79jasper's Avatar
Only way for That to happen is no oil, or failed oil pump. Which isn't common.
No scanner connecting could be multiple problems. Fuse to the obd connector (same as the cigar lighter IIRC) or pcm losing power. (Fuse, relay, shorted fuel heater)
79jasper is offline
post #14 of 26 (permalink) Old 08-11-2018, 10:17 PM Thread Starter
REOutdoors's Avatar
Shorted fuel heater?
post #15 of 26 (permalink) Old 08-11-2018, 10:56 PM Thread Starter
REOutdoors's Avatar
My programmer plugs in and turns on but will not recognize the computer... that’s why I am confused the OBii port powers the programmer
