Differential Cover Replacement - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-04-2013, 03:09 AM Thread Starter
Supporting Member
My Photos: (11)
I am getting ready to replace the fluid in both differentials plus the rear cover with a G2 cover. I know the OEM cover is sealed with permatex type sealant. I am sort of old school and would like to use a Fel Pro gasket which I just happen to have on hand. Have any of you used a gasket vice the sealant? Also I plan on using Royal Purple 75w140 and just how much do I need to fill both front and rear?
Thanks,
Bill
2002 F350 CC, LB, 4X4, 7.3, 6 Speed. Billet Compresor Wheel. Ford AIS Filter. Frx, Hpx, CVD Fittings. Bank's Bighead Actuator, PHP Hydra and a Bunch of Other Mods. Towing 2013 Arctic Fox 27-5L 5th. Wheel. US Navy Retired E8. Hoping for Liberty and Justice for All.
Traildust is offline
post #2 of 5 (permalink) Old 12-04-2013, 05:39 AM
I always use a gasket when available. Nothing wrong with RTV but sometimes residual gear oil likes to run out and if it contacts the uncured RTV you can end up with a a leak.
2000 F350 DRW 7.3
tomlin is offline
post #3 of 5 (permalink) Old 12-04-2013, 09:23 AM
RT
RT's Avatar
FEL-PRO Part # RDS55394 is the gasket. That's all I will use - I hate the silly putty method. Seems they always drool just a little. I've had great success with the gasket. The rear axle uses 6.9 pints, the front 5.8. The manual calls for 90 weight in the front.
RT is offline
post #4 of 5 (permalink) Old 12-04-2013, 12:42 PM Thread Starter
Supporting Member
My Photos: (11)
Thanks for the replies I do appreciate it. Fel Pro RDS55394 Rear and RDS60951 Front I hope. Is that just straight 90 weight gear oil? No synthetic or friction modifier in the front?
post #5 of 5 (permalink) Old 12-04-2013, 01:24 PM
RT
RT's Avatar
That's what the owner's manual calls for - 90 weight hypoid gear oil.
RT is offline
