dipstick adapter - Page 2 - Diesel Forum - TheDieselStop.com
 3Likes
post #16 of 20 (permalink) Old 01-26-2019, 11:29 AM
Calico5's Avatar
Originally Posted by 2000F250-7.3 View Post
Also get some black rtv to put on the adapter between the o-rings to seal it up. The oil pans are not flat and taper a little the rtv will insure it seals up good luck and have fun.
Yeah... no.
I wouldn't recommend using any RTV. The double o-ring design on the new adapter seals very well.
RTV really is NOT your friend around oil systems, IMHO.
panhead george likes this.
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #17 of 20 (permalink) Old 01-28-2019, 09:26 AM
brian42's Avatar
Originally Posted by Calico5 View Post
Yeah... no.
The double o-ring design works great. I have absolutely no leakage.
If you feel the need to seal anything on the oil system I recommend using the Ford TA-31 sealant (RTV). It is specifically designated for use on the 7.3L (says so on the tube) and is what Ford used as the gasket material for the oil pan.
The Money Pit
2003 F-250 7.3L PSD FX4 CCSB, Dual Alternators - 160/80 SS, T500, FRx, 6.0 IC & TC (w/Derale), S&B, RR 4/4 Wheel, EBPV-less, RR OCR, IH Up-Pipes, Hydra (PHP & GH), ISSPRO Gauges, FTVB, 4" MBRP, H&H, Racor PS120, 140A Alternators, North Stars, Dynatrac, XRF, ATS Springs
brian42 is offline
post #18 of 20 (permalink) Old 01-28-2019, 12:45 PM
blue99stroker's Avatar
Some pans are so warped you have to use rtv. It’s in the Instructions now from strictly/driven.
I’m about to order the same adapter.
My friend just installed his and had a big gap at the bottom of the flange that required rtv
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #19 of 20 (permalink) Old 01-28-2019, 01:42 PM
2000F250-7.3's Avatar
Originally Posted by blue99stroker View Post
Some pans are so warped you have to use rtv. Itís in the Instructions now from strictly/driven.
Iím about to order the same adapter.
What blue99stroker said I did a test fit on mine and I had the warp on the pan so not wanting to do it twice I got the high heat made for oil rtv and no problem so far no problems.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #20 of 20 (permalink) Old 01-29-2019, 08:47 AM
brian42's Avatar
I don't think it's a warp as much as the contour of the pan since mine has it too (if it's at the bottom of the adapter).
I just did this a couple of weeks ago and don't remember any mention of RTV in the instructions. With two o-rings and a clean pan surface I figured that would work well enough so did not use any TA-31 when I did the job.
After I installed the "Nugget" I warmed up the truck and ran a few errands close to home to put a few short heat cycles on the engine/oil/pan/o-rings. Haven't had a problem.
Calico5 likes this.
The Money Pit
brian42 is offline
