Filter recommendations - Diesel Forum - TheDieselStop.com
 4Likes
post #1 of 20 (permalink) Old 10-19-2017, 12:56 AM Thread Starter
7.3 here with cold air intake. I bought a K&N filter but it's way too small Any recommendations? Or does it matter?
~Steve
2000 F-350 7.3L
Steve Wiles is offline
post #2 of 20 (permalink) Old 10-19-2017, 02:14 AM
blue99stroker's Avatar
You have the k&n setup with a conical filter?
Or a flat panel k&n filter?
Steve Wiles likes this.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #3 of 20 (permalink) Old 10-19-2017, 07:53 AM
2000F250-7.3's Avatar
I recommend the 6637 filter kit from Riffraff Diesel all the air you will need at a good price.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #4 of 20 (permalink) Old 10-19-2017, 06:46 PM
What brand of intake do you have? You may have to get the filter that is designed for that intake, as some use odd shaped and sized openings.
post #5 of 20 (permalink) Old 10-20-2017, 09:04 PM Thread Starter
cone filter
~Steve
2000 F-350 7.3L
post #6 of 20 (permalink) Old 10-20-2017, 09:05 PM Thread Starter
don't know the brand...or don't remember. But a regular cone filter fits fine.
~Steve
2000 F-350 7.3L
post #7 of 20 (permalink) Old 11-01-2017, 06:06 AM
FWIW, from my experience, I have never saw an oiled gauze filtered intake that wasn't dusted.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock rims/tires & rebuilt 9.19
2 Donaldsons, 3" dp, ACs & Hydra w/PHP & 1023, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, T500, HV LPOP, Aeromotive RR, Auber instruments & IDM mod, KC S300 63/70/84, boost fooler, RiffRaff bellowed up pipes, 6.0 IC & 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #8 of 20 (permalink) Old 11-02-2017, 06:40 PM
The S&B oiled filter seems to do pretty well. I have run mine for about 30k miles and the intake passes the white glove test when it is pulled off to be cleaned.
However, if I were in desert terrain or just a place with a lot of dust, I would stick with the dry paper version.
post #9 of 20 (permalink) Old 11-02-2017, 09:50 PM
chuckster57's Avatar
I realize my IDI doesn?t make the boost a psd does, but my K&N has been in service since ?08 and I don?t have any ?dusting?.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #10 of 20 (permalink) Old 11-03-2017, 06:24 AM
That right there is some good news. Honestly though, I don't think I would still do it?
On a side note:
I had a smoke issue with my tow pig/mild setup. I hooked my manometer to the intake. Long story short; I went from 1 11.5" O.D. Donaldson to TWO. NOTICEABLY LESS SMOKE AND FASTER SPOOLING!
Here is the Donaldson equation I used from my filter research. It's been dummied down, but very close. I did find other reputable companies that had calculations and they all were consistent with one another.
Airflow (CFM) = HP (SAE/max) x SA
SA = (Specific Airflow) per HP. There are different values for 4-stroke, 2-stroke, natural aspirated vs turbo, etc. For the 7.3 Powerstroke, this number is 2.3.
So, CFM = HP X 2.3
This is a CFM airflow rate at the maximum HP your truck outputs.
MeTo is offline
post #11 of 20 (permalink) Old 11-03-2017, 07:40 AM
Donaldson makes a blue filter that flows 1300+
You could have used the one filter instead.
Where are you buying your filters?
The wix,fram 6637 style filters don?t flow enough.
post #12 of 20 (permalink) Old 11-04-2017, 06:42 AM
I didn't invest the time and money because two filters would look cool. Put a manometer on your intake. As for the blue limited release for RiffRaff, I will believe that number when an independent substantiates that 1300+ marketing claim.
MeTo is offline
post #13 of 20 (permalink) Old 11-04-2017, 08:00 AM
MeTo I would love to see pictures of this tow filter setup.
post #14 of 20 (permalink) Old 11-04-2017, 08:30 AM
Manometer measures pressure not CFM.
Train Horns:
post #15 of 20 (permalink) Old 11-04-2017, 09:07 AM
There is such a flow chart posted.
Read it if you want
