Fuel Additives? what is the best? - Diesel Forum - TheDieselStop.com
post #1 of 65 (permalink) Old 05-02-2007, 02:46 PM Thread Starter
Just wonder what is the best to use?
1999 F350 larait crew cab,6-speed,From the Turbo back MBRP 4"exhurst Stainless,6 position Ts chip,AFE Stage II,Dual gauge pod.
F350Cowgirl07 is offline
post #2 of 65 (permalink) Old 05-02-2007, 03:49 PM
Re: Fuel Additives? what is the best?
I use "Lucas" Upper Cylinder Lubricant. It has Injector cleaner and a fuel conditioner in it. I pick it up at Flying J and add 16 Oz every other tank of fuel. Others will chime in with their favorite brand I am sure... Pick what you want and what makes sense to you... We use this in all our work trucks (read this as 5 PSD in 3 areas of the country) I am not sure if it really helps, but I can say this.. the sea foam Filter change made no difference in how the truck ran so this stuff must work all by itself. I put 7000 to 10,000 a month on my truck so we go through a bunch of this stuff.
vanmantraveler is offline
post #3 of 65 (permalink) Old 05-02-2007, 05:37 PM
i run the Diesel Kleen gray bottle in mine and I picked up about 1MPG
and it smokes less.
THEDIESELMAN is offline
post #4 of 65 (permalink) Old 05-02-2007, 06:55 PM
Pappy19's Avatar
My Photos: (6)
I like Stanadyne Performance formula, blue label.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
Pappy19 is offline
post #5 of 65 (permalink) Old 05-02-2007, 10:31 PM
G BURDICK's Avatar
Another vote for Stanadyne Performance Formula [img]/ubbthreads/images/graemlins/grin.gif[/img]
MINE
2001 F350,XLT,CC,4x4,PSD,6-SPD,SRW,156"WB,OFF-ROAD,LS,PTTTM,AIC,PRODIGY P3 BRAKE CONTROLLER,BILSTEIN SHOCKS,TOYO OPEN COUNTRY A/T,HAWK ROTORS AND HAWK LTS PADS,PML REAR DIFF COVER,RHINO LINING,GARMIN NUVI 2595LMT,SIRIUS RADIO,TRUE BLUE
2006 F350,XLT,SC,4x4,6.0L,TORQSHIFT,SRW,142"WB,FX4,LS,E SOF,TOW
COMMAND,UPFITTERS,LINE-X,WEATHERTECH MATS,COOPER DISCOVERER AT3,GARMIN NUVI 1350T,DARK GREEN SATIN W/SILVER
HERS
2009 EXPEDITION EL,LIMITED,4WD,WHITE PLATINUM TRI-COAT,BLACK INTERIOR,DVD,MOONROOF,POWER DEPLOYED RUNNING BOARDS,MOONROOF,WEATHERTECH MATS,GARMIN NUVI 265WT
G BURDICK is offline
post #6 of 65 (permalink) Old 05-02-2007, 11:32 PM
SyN
Alot of good ones out there in the market now.
But I'm partial to lubecontrols---> FP60 and the New FP3000.
Also Use Diesel Treat--->Schaeffers.
2001 F250 XLT CC 4X4 AUTO SWB Toreador Red
BoD>{5-01}-{295K miles}.
Donaldson AIS Intake w/ZooDad
4" MBRP Turbo Back Exhaust.
DieselSite By-Pass Coolant Filter/{ELC}&RMI-25
DieselSite By-Pass Transmission Filter/Lg Magnet
Delete Mods-->{Foil & AIH}
203*{T-Stat}w/Billet Housing
SS HPX line-CCV{to atmosphere}-Bilstien Shoxs
Marinco Heater Plug-B&W Companion 5thWheel Hitch-PML differential Covers
Oil------------>T6 w/Amsoil Filter & Lg Magnet
Amsoil--------> Everywhere Else
SyN is offline
post #7 of 65 (permalink) Old 05-03-2007, 01:05 AM
Look here I won't ever use power service again.
Also....http://www.[another diesel site called [tdg]].com/forums/showthread.php?t=36024
schmity is offline
post #8 of 65 (permalink) Old 05-03-2007, 01:46 AM
The info has been removed so what did it say and what made it so bad.
post #9 of 65 (permalink) Old 05-03-2007, 04:01 AM
You'll find that Stanadyne's Performance Formula Diesel Fuel Additive is designed for our injectors and fully approved by Ford and Navistar. I've used it since the 90's and have never had a lubricity problem on my older 7.3L IDI Engines that NEED more lubricity than our PSDs. When other diesel trucks were having problems in minus 25 degree F weather a few months ago high in the Rockies my 7.3L PSD had none. I normally put only 2 oz in at every fill-up except when the weather is below freezing when I put 4 oz in my 29 gal tank. It is a lot cheaper than putting in 2 cycle oil which is not formulated to keep your injectors clean.
Click on the Stanadyne's Performance Formula Diesel Fuel Additive URL I put in the first line of my reply above and after reading what it has to say your decision will be easy.
Good luck
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF Transmission, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
jlrsn is offline
post #10 of 65 (permalink) Old 05-03-2007, 10:33 AM
In a nutshell Diesel kleen (as well as most of the addatives) contain mineral spirits, xylene, and naptha none of which are lubricants. If anything these addatives barely meet the same HFRR rating as ultra low sulfur diesel, but certainly do not add any lubrication. Maybe they are good to clean the fuel system or to add cetane, but not to increase lubrication.
Mopar1973Man claims that Power Service requested that the information about there product be removed or they were going to follow up with a law-suit (look at the post on the Deisel Gerage...the link is on this page ). Bottom line is that Power Service didn't like what they saw and did not make any effort to dispute the info...they just simply flexed their muscles.
Basically the only addatives that claim not to be solvents are lucas and howes...stanadyne does not claim to have any lubricants (not sure about their lubricicity formula however). I've been running 2 cycle oil in my fuel for about 10K now.
02 DRW 2WD 4DR PSD 4.10 Limited Slip, DP Chip 4-position chip, Van Turbo w/ATS housing, Dieselsite Boot Kit, Tymar Intake, 6.0 Spearco IC, Magnaflow 4" Exhaust, Pyrometer, Boost, Trans Temp, Trucool.
schmity is offline
post #11 of 65 (permalink) Old 05-03-2007, 12:20 PM
Stanadyne Performance Formula all the way!
grungepuppy is offline
post #12 of 65 (permalink) Old 05-03-2007, 12:27 PM
Pappy19's Avatar
My Photos: (6)
I get my Stanadyne Performance Blue Label from these guys; even with shipping 2 cases, they are cheaper than anywhere else that I've found:
http://www.stanadyne.com/new/ppt/ppt...p?dealerID=114
Pappy19 is offline
post #13 of 65 (permalink) Old 05-03-2007, 01:53 PM
I use the 2 old standby's, Marvel Mystery yOil and Sea Foam. I run Marvel oil for 5 tanks and then one tank with the sea foam. Marvel is a great lubricant, but I am not so sure about how well it cleans the fuel system. That's why on the sixth tank I run Sea Foam - I know it cleans very well.
Shawn Zeller
02 F250 Crew, 4X4 Off Road, 3.73, Edge Juice w/ Attitude
K&N Generation 2 Performance Air Intake
02psdcrew is offline
post #14 of 65 (permalink) Old 05-03-2007, 02:56 PM
This is from the other site.
Howes is good... It contains mineral oil for a lubricant. But Standyne don't contain any lubricants.
We are after lubricants more that a certane booster... Very few (I mean very few) products are even concerned about lubricants in there products. I don't mean to comply with 520 HFRR I mean to exceed it by head towards 200-300 HFRR which none of these products can or will do because of EPA regulations. So it up to us to homebrew our own solutions.
Marvel Mystery Oil is basically Naptha, Mineral Spirits, and Clorinated Hydrocarbons.
Be your own judge.
schmity is offline
post #15 of 65 (permalink) Old 05-03-2007, 05:09 PM
Flywheel's Avatar
I thought you could just run canola oil - just put some in?
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
