Fuel filters - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 04-19-2019, 08:42 PM Thread Starter
Absolute's Avatar
Fuel filters
I have a stock 02 7.3. Not the one in my signature, this one is bone stock. I went to change the fuel filter and do a bowl rebuild, the drain leaks, so might as well. Great success with the Riffraff rebuild kit, except the filter. The filter they, and everyone else I try, provide is number PFF 4596. It is totally different and don't fit, and cant fit. It is a filter, with the black plastic square screen all attached together. Mine, is just a filter. THe square screen is part of the lid, and doesn't come apart, its molded all one piece. Also the lid O ring provided is wedge shaped, mine is flat and much wider, but a bit thinner. The number on my filter, the one I can't find is PF5419. Totally different. Can anyone direct me to a provider so I don't have to bend over for ford? If they even have it. SO odd I can't find it. Wonder if I have the old bowl off my signature truck. Hate to rebuild another bowl just because I can't find the filter for this one.
Absolute is offline
post #2 of 10 (permalink) Old 04-20-2019, 06:15 AM Thread Starter
Absolute's Avatar
Wow, crickets. Guess everyone has the same issue I have, can't find one. Not sure why this bowl is a rare one. No one even gets a cross reference for this filter. Only one available is the one with the black plastic screen attached. Gonna try ford today, couldn't find my old bowl off my signature truck.
Absolute is offline
post #3 of 10 (permalink) Old 04-20-2019, 06:24 AM
ArcticDriver's Avatar
Absolute,
Any chance you typed a number wrong? I cannot find a PF5419 using Google search.
The PFF4596 is a Racor filter. Racor makes quality filters:
https://www.riffraffdiesel.com/oem-fuel-filter-99-03/
This wedge design o-ring (gasket) is a “tried & true” design and nothing to worry about. It has a 5-star rating with 81 Reviews.
It is the proper filter for a 2002 7.3PSD so if it doesn’t fit then something strange is going on because your rebuild kit fit your fuel bowl, right?
If you can find a different P/N then I can help you search.
SOLD:
ArcticDriver is offline
post #4 of 10 (permalink) Old 04-20-2019, 06:29 AM
You posted while I was responding.
If the Racor does not fit then the Ford Motorcraft will not fit. They are the same OEM dimension.
EDIT:
I just found the Racor has been the manufacturer of Motorcraft fuel filters.
Maybe you can hold them up for comparison without taking any plastic wrap off right at the Ford Parts counter before dropping the Loonies.
SOLD:
post #5 of 10 (permalink) Old 04-20-2019, 07:02 AM Thread Starter
Absolute's Avatar
THe filter part,( meaning the paper filter) is identical, as is the rest of the bowl. The 4596 is a filter like I have, with a black plastic piece around it, with square holes and a thin screen type filter over square holes. On mine, that part is part of the lid, its not part of the filter. So everything is identical, except the filter on mine does not come with the plastic part. I would need a new lid with out the plastic to use this filter.Or any other I can find. 5419 is the number, is printed on the filter, same spot as the new one with the 4596 number. The difference is the lid. My lid has a screen attached, everyone elses does not have the screen attached, the screen comes with the filter. Not sure how this truck got this set up. Its totally stock from Texas. The Bowl is identical to the drawing provided with the rebuild kit, except the lid. Drawing lid has no screen obviously. Tried to take the new filter off the screen part, but its molded together, no go. I now have a dead work truck, I already cut the filter to inspect it, so have nothing to put back in. Gonna take the old filter to ford, see if they can match it, if not , guess i'm ordering a new lid to work with the filter. The wedge gasket wont work either. Its the right diameter, but does not fit the seat it sits in. It has to be flat like the stock one.
Absolute is offline
post #6 of 10 (permalink) Old 04-20-2019, 07:39 AM Thread Starter
Absolute's Avatar
Well, I may have found one, but its too far away. So again have to check ford. Rock Auto has several brands including OEM. One of the OEM ones they have are a filter with the lid, then they have the 4596 style, and the 4596 style with separate lid kit. So I think the filter with lid is the one like mine were the screen is part of the lid, not filter. Picture isn't clear so can't really tell unless I call them. Shipping time keeps my truck out for too long, so still going to ford for either a filter or lid. Either will solve my issue. Lid is probably better since I wont go threw this again. I just hope they have the lid with all the pockets on top, and not the dome with plastic bolt top. Had that on my signature truck before my fass system, the nut stripped on the first change, nightmare getting it off , destroyed it. Piece of junk.Bought the fass system. The pocket style is niece, you can use the outer pockets to undo it with lots of torque, no mangling it.
Absolute is offline
post #7 of 10 (permalink) Old 04-20-2019, 09:04 AM Thread Starter
Absolute's Avatar
Lol. Bit of an update. I contacted Riffraff about the kit to see if they could help find this filter. Got a speedy reply, thank you, but the info was a bit baffling. They said that the OEM filter will not work with my aftermarket Chinese lid. Hahaha. Unfortunately, I have owned this truck since it left the dealers show room. An it is 100% stock, and I have never changed the lid or the O ring on the lid. The filters used to be available and I used to get them without incident. Hadn't used this truck for years, no more than 1000 miles a year on it. Now I can't find them and apparently my truck came from factory with aftermarket parts on it?????????????
Absolute is offline
post #8 of 10 (permalink) Old 04-20-2019, 10:35 AM
Yep.
A new OEM lid will set you free.
That link to RiffRaff in my earlier post had a Motorcraft lid for $16 USD.
To be honest, that old lid you had with the outer mesh being a single molded piece sounds like a bad design because the outer mesh is the water seperator and the chemical applied to it would have long since worn out.
Basically, you would be left with a fuel filter but no longer a water seperator if I understand your description.
SOLD:
post #9 of 10 (permalink) Old 04-20-2019, 02:50 PM Thread Starter
Absolute's Avatar
I ended up getting a new lid from ford. I wont tell you the price. lol
Absolute is offline
post #10 of 10 (permalink) Old 04-23-2019, 08:52 AM
Originally Posted by ArcticDriver View Post
Absolute,
I used the Racor filter, wedge gasket, OEM style lid on mine without any problems on my 7.3. It's gone now, still have a spare filter kit w/ lid sitting in storage. Maybe I'll find a home for it one day.
2001 F-250 XLT 4X2, 7.3L, 4R100, 158,000 miles
Cat ELC, ScanGauge II, SC 1705, Dahl fuel filter
Dieselsite transmission and coolant filters
Hawk LTS pads, Ford Severe Duty AIS, Isspro EV2 gauges
Uncle Salty is offline
Similar Threads
Water in fuel removal additive ajohansson General Diesel 5 09-26-2013 01:51 PM
Diesel Fuel Additive Chart - Anyone got a copy? mbot 6.4L Power Stroke Engine and Drivetrain 2 05-31-2011 07:33 PM
2 Stroke Oil redneck_rheino 6.0L Power Stroke Engine and Drivetrain 94 03-23-2011 08:37 PM
What to add to fuel for lubrication??? HorsePilot General Diesel 9 05-25-2010 02:36 PM
How HEUI works and best to convert fordnut74 Bio-Diesel and Alternative Fuels 3 10-21-2009 11:51 PM
