Fuel Pressure Problem - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 08-24-2019, 06:00 PM Thread Starter
clev's Avatar
My Photos: (16)
1999 E350 7.3 diesel, 147k miles, always garaged, hooked to double battery tender, and well maintained. A couple of years ago, I modded the fuel tank, installed an Air Dog, and upgraded the fuel pressure regulator in the Fuel Bowl. Fuel pressure was 67, dropped to 60 when pulling out or romping on it, but would quickly return to 67. Since May, I've had to be away and have returned home 3 times in the last 4 months; the van has been started 3 times. Last month, it was hard to start, slow long cranks and the fuel pressure was 58, which zeroed when pulling out or romping. Pressure is slow to recover, sometimes only to about 50. Called Air Dog Tech, and he recommended changing the fuel filters. I did that this time, but no improvement. Am I looking at an HPOP problem? What can anyone recommend for troubleshooting?
2012 F-350 SD Crew Cab, SRW, LWB, 4 X 4, FX4 Offroad, Bilsteins and Bilstein Steering Stableizer, AirLift Air Bags with onboard compressor, BedLocker electric bed cover, Hellwig 1 1/4 inch rear anti-sway bar, 2017 G37 Turbo, ATS Stage I towing transmission kit, White Platinum w/Adobe, Navigation, Moon Roof, 5th Wheel Prep, Step Tail Gate, front 2 inch receiver, completely insulated, Pioneer speakers, King Ranch Package
'99 E-350 HiTop Companion Van Conversion, 7.3 SD Diesel, 5-tune DP Tuner, Triple AutoMeter C2 A-pillar gauge pod, dash mount AutoMeter C2 fuel pressure gauge, twin K&N's, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust, Air Dog fuel filtration system, Hutch mod, header wrapped and high temperature painted Bellowed Up-Pipes.
clev is offline
post #2 of 7 (permalink) Old 08-24-2019, 07:08 PM
RT
RT's Avatar
I donít see how it could be an HPOP problem. Could be the pump, regulator, sucking air, restriction in the pre-pump line or a bad sender. My oil pressure sender went out like this. I had already ordered new bearings before I swapped the sender. Pressure is back to where it was new...
RT is online now
post #3 of 7 (permalink) Old 08-24-2019, 07:32 PM Thread Starter
clev's Avatar
My Photos: (16)
Thanks RT. Where is the sender located?
clev is offline
post #4 of 7 (permalink) Old 08-25-2019, 06:16 AM
RT
RT's Avatar
Since the truck didnít come with fuel pressure, it would have to be wherever you put it. Mine is screwed into the back of my fuel bowl. Some people use an isolation hose from the fuel bowl to a sending unit. Fass might have a mount on their filter housing..
RT is online now
post #5 of 7 (permalink) Old 08-25-2019, 07:37 AM Thread Starter
clev's Avatar
My Photos: (16)
Yes, I installed the fuel pressure regulator in the fuel bowl housing. You mentioned an oil pressure sending unit causing your problems. I was referring to that.
clev is offline
post #6 of 7 (permalink) Old 08-25-2019, 12:38 PM
RT
RT's Avatar
I was just using that as an example of how a sending unit can fail making you think you have a problem when you donít.
RT is online now
post #7 of 7 (permalink) Old 08-25-2019, 01:01 PM Thread Starter
clev's Avatar
My Photos: (16)
I misunderstood. I’m not sure where to even begin to troubleshoot. I may have to take it to the Ford garage.
clev is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
xblowhard
