Fuse # 19 blows. Engine stays running but No forward movement - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By RT
post #1 of 5 (permalink) Old 07-14-2019, 08:45 PM Thread Starter
Question Fuse # 19 blows. Engine stays running but No forward movement
'99 F250 7.3 I was driving in Houston traffic over the weekend when my instrument cluster all went dead. The engine is still running but after a few minutes it disengaged and I had no acceleration. I managed to coast into a parking lot & replace the fuse (#19 under dash) and it ran for about 15 min then popped again. Sometimes if I slipped into neutral then back into drive it would catch again but it finally said no. I was on back roads nearly home at this point so I was able to just put it in 2nd and drive slow and it stayed engaged.
Anyway, this fuse controls several different functions and I can't determine what is cause and what is effect to figure out why it's blowing. I'm suspicious of the gearshift with the little wire going to the OD shutoff switch just because of it being in a stress bending point. I pulled the switch out but that didn't help.
I also have a leak I can't pinpoint that lets water in behind the petals when it rains. It's near the electronics / fuse mess under the dash but I haven't seen any of that wet. It comes in from behind the plastic near where the steering column goes through the firewall and gets the floor wet right behind the petals. ( I would LOVE to find the entry point and fix that!!)
I welcome any ideas!
Farm-Mom NW of Houston, Texas
99 F250 Super Duty 7.3 Crew Cab,
2WD, Automatic, short bed. RED
381K w/original engine & tranny
"Big Red"
FarmMom is offline
post #2 of 5 (permalink) Old 07-14-2019, 11:16 PM
woodnthings8's Avatar
Check out my article. Your shifter wire is the fault.
https://docs.google.com/viewer?a=v&p...M2Q5YjdmODQ4NQ
Sent from my SM-G965U using Tapatalk
Ken
2002 F-350 CCLB 4X4, HD4R100 , Riffraff FRx, Riffraff CAC Boots & PRI's, Bellowed Up-Pipes, 4" Diamond Eye exhaust, Powerslot rotors,
, DP Tuner-F6, Autoenginuity, EEC-V Breakout Box, KCM S.S. HPX Line, S&B Filters intake, Quad Autometer gauge pod, Inovations canopy, Banks Big Head wastegate actuator, 6.0L Trans Cooler,
Zoo-dad, Dieselsite Coolant Filter, Cobra 29LTD/NW CB, DVD and always looking to do more....
woodnthings8 is offline
post #3 of 5 (permalink) Old 07-15-2019, 04:25 PM Thread Starter
Thank you! I'll pull that apart asap and see if it can be patched...
"Big Red"
FarmMom is offline
post #4 of 5 (permalink) Old 07-15-2019, 06:51 PM
RT
RT's Avatar
KEN! You're alive! Haven't seen you around for ages. Hope you are doing well.
I wouldn't patch it myself - a new shifter isn't that expensive. What you can do is disconnect the plug and leave it disconnected until your new shifter comes in?
woodnthings8 likes this.
RT is offline
post #5 of 5 (permalink) Old 07-15-2019, 07:41 PM
I am and doing well. Just crazy busy with work and life overall. I don't get as much "online" time as I used to with forums.
Ken
