Glaw Plug Carbon Build-Up - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 08-31-2019, 06:05 PM Thread Starter
ArcticDriver's Avatar
Bought the truck 17 months ago. GP History unknown. All of the old were BERU.
While replacing all 8 GPs with ZD-11, I found #3 GP very heavy with carbon on the sleeve (not the element). The other 7 were clean (photo).
Threads are good and the new GP snugged to 14 ft-lbs solid.
It Ohms fine.
Suggestions?
Bad Injector o-ring?
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #2 of 6 (permalink) Old 08-31-2019, 06:13 PM Thread Starter
The carbon build-up extends up above the threads. This makes me think it might have come loose at some point in the hole.
It did not feel loose as I started to untighten it but I think the carbon had seized the threads.
Sound reasonable?
SOLD:
post #3 of 6 (permalink) Old 09-01-2019, 04:08 PM
RT
RT's Avatar
I think it must have not been torqued properly when installed. I can't think of anything else that would allow carbon to deposit up to and including the threads.
RT is offline
post #4 of 6 (permalink) Old 09-01-2019, 06:49 PM Thread Starter
Glow Plug Carbon Build-Up
Thanks RT !
Always good to get your insight.
SOLD:
post #5 of 6 (permalink) Old 09-02-2019, 11:30 PM
klhansen's Avatar
My Photos: (180)
I'd agree it wasn't properly installed. They seal at that shoulder down near the tip. I suppose it's also possible there was a defect in the sealing surface (tapered seat).
), AIS,
regulated return,
klhansen is offline
post #6 of 6 (permalink) Old 09-04-2019, 08:02 AM Thread Starter
Thanks Kevin,
I think I will pull the valve cover and check it at around 2,000 miles.
SOLD:
