Groan at idle - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 04-08-2019, 08:20 PM Thread Starter
Deeds86's Avatar
Groan at idle
I'm trying to resolve a few issues now that spring is about, and I'm really having a hard time pinpointing my issue... I have an unsteady groan at idle it's not extremely loud but loud enough that my passengers ask after a short amount of time...it goes away with just a tiny bit of rpm, originally I was suspecting the backpressure valve but don't think that's it, I can't see really any imbalance in the harmonic balancer and the only other thing I can think is my very slight leak in my exhaust manifold is causing this groan does anyone have any ideas on anything else I can try that would be causing my issues. It is in almost the same rhythm as my backpressure valve when it's cold, and can only hear it from inside the cab... laying underneath motor or cab there is no sign of the groan
Deeds86 is online now
post #2 of 4 (permalink) Old 04-08-2019, 11:31 PM
ArcticDriver's Avatar
When I think of a “groan”, I think of the sound of an overloaded suspension.
Can you think of another descriptive word ?
Is it a bearing growl?
A jet engine sound like a closed EBPV?
A wooshing sound like air?
SOLD:
ArcticDriver is offline
post #3 of 4 (permalink) Old 04-10-2019, 04:54 AM Thread Starter
Deeds86's Avatar
Yeah maybe more a bearing sound is what I'm leaning towards...its definetly not the ebpv whoosh it's a deeper note and it will do it in drive or park but only at under 800 or so rpm my local diesel shop hears it but can't pinpoint where it's coming from so I thought I'd ask the forum if anything comes to mind... I still thinks its power steering cause when I move the wheel the sound speeds up and when I hold on the wheel so it's working the pump I can almost make it go away
post #4 of 4 (permalink) Old 04-10-2019, 11:29 PM
You might check your PS fluid level. Low or old fluid can cause the pump to make a growling sound.
Do you know if the fluid has been changed? (Note: Its actually ATF fluid.)
As you probably know, your power steering pump also provides pressure to the hydroboost for the brake assist.
IF it is your power steering pump then I would find a new shop because if they couldn't track that down then you don't want them wrenching on anything...Lol
SOLD:
Similar Threads
8V92 idle not steady Quikerstop General Diesel 2 08-28-2010 08:44 PM
Rough idle, a continuation of my problems? moonshiner Power Strokes 1994-1997 General 1 03-12-2007 09:04 PM
NO DASH INDICATIONS, but she'll start and only IDLE, but when warm is OK phil2810 '99 & up 7.3L Power Stroke Engine and Drivetrain 8 02-14-2007 08:08 PM
smoke at idle quackattak 7.3L IDI Diesels (Not Power Strokes) 17 11-27-2005 05:38 AM
'02 SuperDuty ?s tankdog 1999-2007 Ordering Information 27 08-12-2001 10:24 AM
