HELP! 2003 F250 SD 7.3 manual 6spd no power after 20 minutes driving - Page 3 - Diesel Forum - TheDieselStop.com
 3Likes
post #31 of 37 (permalink) Old 03-31-2019, 04:36 AM Thread Starter
Hey Kevin, Thanks, is there a how to link somewhere to do this. Planning to change O rings on drivers side after church today to see whether there are any Orings that are bad. Thanks so much,Duane
saltypop is offline
post #32 of 37 (permalink) Old 03-31-2019, 06:55 PM
Gray02Dually's Avatar
Location: Native Texan for 54 years. moved to south central Missouri
I was thinking along similar lines. I'll bet it's either losing power to the frame-rail mounted pump or it's got a partial clog and can't deliver enough fuel at highway speed. I had a fuel pump get clogged and saw similar symptoms as Saltypop. I could idle it but pulling a load, it would run out of fuel.
My situation was easier to diagnose because I knew that I had probably trashed it from old fuel in an aftermarked auxiliary tank. I have an in-bed 110 gallon that I hadn't used in a while and then put diesel in and tried running on it. Failed almost immediately. I get the impression that they barely supply adequate fuel under load even when new. just my humble opinion...
'02 7.3L 6spd Manual, 2WD
Air Springs, Exhaust Brake, HPX, 110 Gallon auxiliary fuel tank
Gray02Dually is offline
post #33 of 37 (permalink) Old 03-31-2019, 10:27 PM
klhansen's Avatar
My Photos: (180)
You'd have to identify the hot wire going to the fuel pump, splice into that and connect your indicator light between that and ground. Should be the pink/black wire at the fuel pump, or you could intercept either wire at the fuel pump cutoff switch on the right side kick panel.
), AIS,
regulated return,
klhansen is offline
post #34 of 37 (permalink) Old 04-01-2019, 12:13 AM Thread Starter
hey Kevin , i think i understand now.
Even though it's a new pump it could still be not getting power correct?
saltypop is offline
post #35 of 37 (permalink) Old 04-01-2019, 07:24 PM
klhansen's Avatar
My Photos: (180)
That was my thought. I did notice when looking at the wiring diagram for the wire color, that the PCM does monitor the fuel pump secondary power circuit, but not sure what it does with it at the moment. I may have to dig into that for you.
), AIS,
regulated return,
klhansen is offline
post #36 of 37 (permalink) Old 04-02-2019, 08:40 AM Thread Starter
hey Kevin, Thanks so much! At the moment plan to update tomorrow on where we are.
saltypop is offline
post #37 of 37 (permalink) Old 04-30-2019, 10:14 PM Thread Starter
UPDATE: GOING INTO 6 WEEKS CONFIRMED IT WAS INJECTORS. We changed them all out today and truck is running,
now to fix the ac that went out during all of this. RT Thanks for Keeping tabs on me so i didn't get discouraged!
aclasshog likes this.
saltypop is offline
Similar Threads
2002-2007 Ford F250 Super Duty Truck Power Heated Signal & Clearance Light Textured Black Dual Arm Power - Folding 1AAuto.com 1A Auto Parts 2 01-15-2016 08:43 AM
1999-2007 Ford F250 Super Duty Truck Power Textured Black Dual Arm Power - Folding Towing Mirror with Manual Spotte 1AAuto.com 1A Auto Parts 1 05-13-2015 07:34 AM
Anyone know what this line? goes to on our 03 f250 manual 6spd 7.3 4x4 saltypop '99 & up 7.3L Power Stroke Engine and Drivetrain 4 12-17-2011 01:38 PM
HELP! 2003 f250 4x4 6spd manual keeps leaving me stranded need AE test saltypop '99 & up 7.3L Power Stroke Engine and Drivetrain 26 12-16-2011 06:49 PM
Taking the Plunge, first performance modifications DarthSurplus '99 & up Upgrades and Aftermarket - 7.3L Engine 7 07-27-2005 11:05 AM
