Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   '99 & up 7.3L Power Stroke Engine and Drivetrain (https://www.thedieselstop.com/forums/f24/)
-   -   Help (https://www.thedieselstop.com/forums/f24/help-651201/)
cdanberg1971 08-08-2018 10:16 PM
Help
Need know which direction the lever for water fuel separator i changed it but didnt pay attention to way it came off also the two holes pin hole and another hole im trying find pics but no luck please help
Sent from my SM-G930P using Tapatalk
klhansen 08-08-2018 10:21 PM
It only goes in one way. The lever lays against the filter housing when closed.
Did you disassemble the entire valve?
Here's a set of photos for a 94-97 fuel drain valve. The 99-03 7.3L drain valves are the same except they have 4 mounting screws instead of 2.TheDieselStop.Com Photo Hosting - 94-97 Fuel Drain Valve
cdanberg1971 08-08-2018 10:24 PM
Just took off the old fuel water separator valve with brown or yellow lever
cdanberg1971 08-08-2018 10:25 PM
So it goes side ways to fuel filter housing not pointing straight to turbo
klhansen 08-09-2018 01:14 AM
Closed position is pointing toward the driver's side, and open is pointing toward the turbo.
cdanberg1971 08-09-2018 01:16 AM
Do you want it closed or open sorry sound dumb im just learning
cdanberg1971 08-09-2018 01:18 AM
Im rebuilding a f250 7.3 4x4 truck was wrecked also trying to source parts im not out of water yet because i got codes from check engine light put a new cps from ford on it but still have codes
ArcticDriver 08-09-2018 01:20 AM
Posting the codes would help community diagnose.
You did clear the codes?
ArcticDriver 08-09-2018 01:24 AM
Open is for draining fuel bowl when replacing fuel filter or maintenance type flushing.
Closed is for the rest of the time.
cdanberg1971 08-09-2018 07:36 AM
No i havent cleared codes yet
cdanberg1971 08-09-2018 07:38 AM
Codeshttps://uploads.tapatalk-cdn.com/201...9ab67d33ff.jpg
cdanberg1971 08-09-2018 09:27 AM
Codes cleared now still check engine light on due to low voltage on alt would that cause light go on again ?
cdanberg1971 08-09-2018 09:58 PM
How does a low voltage alt turn on check engine light????
2000F250-7.3 08-10-2018 01:33 PM
Help
If the alternator is over charging or under charging it should set the battery light off. Letting you know there is a problem.
cdanberg1971 08-10-2018 11:56 PM
Im getting code po 1106 dual alt low fault
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
