Help - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 08-08-2018, 10:16 PM Thread Starter
Help
Need know which direction the lever for water fuel separator i changed it but didnt pay attention to way it came off also the two holes pin hole and another hole im trying find pics but no luck please help
Sent from my SM-G930P using Tapatalk
cdanberg1971 is offline
post #2 of 16 (permalink) Old 08-08-2018, 10:21 PM
klhansen's Avatar
My Photos: (180)
It only goes in one way. The lever lays against the filter housing when closed.
Did you disassemble the entire valve?
Here's a set of photos for a 94-97 fuel drain valve. The 99-03 7.3L drain valves are the same except they have 4 mounting screws instead of 2.TheDieselStop.Com Photo Hosting - 94-97 Fuel Drain Valve
), AIS,
regulated return,
klhansen is offline
post #3 of 16 (permalink) Old 08-08-2018, 10:24 PM Thread Starter
Just took off the old fuel water separator valve with brown or yellow lever
post #4 of 16 (permalink) Old 08-08-2018, 10:25 PM Thread Starter
So it goes side ways to fuel filter housing not pointing straight to turbo
post #5 of 16 (permalink) Old 08-09-2018, 01:14 AM
klhansen's Avatar
My Photos: (180)
Closed position is pointing toward the driver's side, and open is pointing toward the turbo.
), AIS,
regulated return,
klhansen is offline
post #6 of 16 (permalink) Old 08-09-2018, 01:16 AM Thread Starter
Do you want it closed or open sorry sound dumb im just learning
post #7 of 16 (permalink) Old 08-09-2018, 01:18 AM Thread Starter
Im rebuilding a f250 7.3 4x4 truck was wrecked also trying to source parts im not out of water yet because i got codes from check engine light put a new cps from ford on it but still have codes
post #8 of 16 (permalink) Old 08-09-2018, 01:20 AM
ArcticDriver's Avatar
Posting the codes would help community diagnose.
You did clear the codes?
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is online now
post #9 of 16 (permalink) Old 08-09-2018, 01:24 AM
Open is for draining fuel bowl when replacing fuel filter or maintenance type flushing.
Closed is for the rest of the time.
SOLD:
post #10 of 16 (permalink) Old 08-09-2018, 07:36 AM Thread Starter
No i havent cleared codes yet
post #11 of 16 (permalink) Old 08-09-2018, 07:38 AM Thread Starter
Codes
post #12 of 16 (permalink) Old 08-09-2018, 09:27 AM Thread Starter
Codes
Codes cleared now still check engine light on due to low voltage on alt would that cause light go on again ?
post #13 of 16 (permalink) Old 08-09-2018, 09:58 PM Thread Starter
How does a low voltage alt turn on check engine light????
post #14 of 16 (permalink) Old 08-10-2018, 01:33 PM
2000F250-7.3's Avatar
Help
If the alternator is over charging or under charging it should set the battery light off. Letting you know there is a problem.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #15 of 16 (permalink) Old 08-10-2018, 11:56 PM Thread Starter
Im getting code po 1106 dual alt low fault
