Higher EGT than normal - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 10-01-2018, 09:56 PM Thread Starter
cellfisha's Avatar
Hello Gents,
I have a good question about my EGTís. Since the new engine install, my EGTís really havenít went above 650-675 and that was climbing a pretty good grade and a few miles at that grade, at about 50-55 mph.
Today, I was heading to Breckinridge and I was on pretty flat land. I noticed my EGTís were at 712 and I was running about 65. At that speed, they are usually around 450-475. Sometimes 500. I first noticed that my oil temp was at 210 and wasnít dropping any. I was up in the highlands and the outside temp was pretty cool. Around 60-65 degrees.
What I did today that I havenít done since the new engine install, was I added diesel Klein to the fuel. Would the diesel Kleen make the EGTís run higher?
I ended up pulling over in FairPlay and I took the red vacuum line off the EBVP as I remember reading here somewhere that if it was stuck closed, that would help to possibly open it. When I arrived in Breckinridge, I looked under the hood again and noticed the green line wasnít in the tube come from the air filter. I put the back in the black tube and also put the red one back where it belonged.
What I did notice after I disconnect the red vac tube, going up grade, the EGTís went up to about 712 again but when I would give it more fuel, they came down to like 685-690.
Iím curious to hear what this could be.
2002 F-350 CC Lariat SRW 4x4 7.3 auto trans, Flat bed, 160cc single shots, infinity mini, 60hp tow, 60hp daily, 80hp daily. Stock exhaust.
1997 F-150 supercab 3 door XLT stepside 4x4 4.6L V8 auto trans 4" lift (SOLD)
cellfisha is offline
post #2 of 12 (permalink) Old 10-01-2018, 10:50 PM
ArcticDriver's Avatar
I don’t think fuel additive is causing these EGT changes.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #3 of 12 (permalink) Old 10-02-2018, 08:57 AM
69mach1377's Avatar
What kind of gage will tell you 712*, seems like an odd but very precise number...
2000 F250 XLT 4x4 SC 7.3 w/rebuilt 4R100, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods, lakes and streams if possible.
See my album for a recent pic.
69mach1377 is offline
post #4 of 12 (permalink) Old 10-02-2018, 06:19 PM
EGT Normal?
Cellfisha, your equipment signature is incomplete. Is your pyrometer mounted pre or post turbo and do you have a stock or modified exhaust system? Most people here have their pyrometer mounted pre turbo, right in the exhaust manifold but there are still a few that mounted them post turbo. Two different critera. So, in order to answer your question one would have to know, not assume, pyrometer mounting position and details about your exhaust. For instance my system, I mounted my pyrometer pre turbo right in the DS exhaust manifold and have stock pipes but opened it up on the back end with a non restrictive BTM muffler..
2002 F250 7.3L PSD, bought new now at 226K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #5 of 12 (permalink) Old 10-02-2018, 11:19 PM Thread Starter
cellfisha's Avatar
My pyrometer is pre turbo. Itís mounted the same place yours is. I have stock exhaust system.
post #6 of 12 (permalink) Old 10-02-2018, 11:23 PM Thread Starter
cellfisha's Avatar
Well, mine is at the moment. Not that itís correct. It doesnít start out at 712, but works itís way there. Doesnít stay at 712 the entire time, so thereís definitely a problem.
post #7 of 12 (permalink) Old 10-02-2018, 11:29 PM Thread Starter
cellfisha's Avatar
Originally Posted by ArcticDriver View Post
I donít think fuel additive is causing these EGT changes.
Hey ArcticDriver. I didnít have a EGT hooked up till I had the newer engine installed, so I never knew what it was doing before. Iíve always used the fuel additive in the truck. Just didnít put any in since I had the newer 7.3 installed. Just sorta freaked me out because this didnít start till I added the additive and started making my way up into the mountains. Maybe I need to check my pyro and see if it has moved from itís original location.
post #8 of 12 (permalink) Old 10-02-2018, 11:48 PM
Calico5's Avatar
Originally Posted by cellfisha View Post
I took the red vacuum line off the EBVP as I remember reading here somewhere that if it was stuck closed, that would help to possibly open it. When I arrived in Breckinridge, I looked under the hood again and noticed the green line wasn’t in the tube come from the air filter. I put the back in the black tube and also put the red one back where it belonged.
FYI:
Those tubes are not the EBPV controls, and they are not vacuum lines.
They are the turbo wastegate controls, that connect through the wastegate solenoid control valve. It allows the PCM to control/limit the turbo speed and boost by either: Letting boost signal go to the wastegate actuator diaphragm (which opens the wastegate), OR, venting the boost signal to the intake, which keeps the gate closed.
Name:	WGC Diagram.jpg
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #9 of 12 (permalink) Old 10-02-2018, 11:59 PM Thread Starter
cellfisha's Avatar
Originally Posted by Calico5 View Post
FYI:
Thank you for the correction. 😀
post #10 of 12 (permalink) Old 10-03-2018, 08:25 AM
69mach1377's Avatar
Well, mine is at the moment. Not that it’s correct. It doesn’t start out at 712, but works it’s way there. Doesn’t stay at 712 the entire time, so there’s definitely a problem.
Seriously, what brand and style?
post #11 of 12 (permalink) Old 10-03-2018, 08:50 AM
Thanks for clearing up the pre or post turbo pyrometer positioning. Your EGT's don't seem excessive compared to mine but admittedly we don't have mountains or grades to compare to Colorado in Alabama where I live. You could lower your EGTs by installing a non restrictive muffler like a BTM, the stock muffler is very restrictive not allowing straight line flow out. My EGTs at 5 PSI boost, 2000 RPM, unloaded 70 mph on flat interstate highway are 700. But they might go higher going up a slight grade in traffic at 40, engine lugging a bit before auto kick down. So there are many variables that effect EGT but what you report does not seem unusual.
Oneof6 is offline
post #12 of 12 (permalink) Old 10-09-2018, 08:50 AM Thread Starter
cellfisha's Avatar
Something has changed. Not sure what but Iím going to get it figured out. My truck seems to be a lot different than yours. At 70 mph my boost might be 2.3-2.5 psi at 1900. I try to keep it at 2000 rpms or less to save on fuel.
Right after the new to me engine was installed, I could climb the same grades and drive the same roads and things were very different. Climbing the mountain pass, EGT was never over 700 and driving flatland, they were never more than 500. That was not pulling anything. Crew cab was loaded with tools, but nothing on the flatbed.
Iíll keep yall posted on my findings.
